Is this normal on Kiotis?
   / Is this normal on Kiotis? #21
My HST Max 28, creeps a little both on the level or on hills and IMHO it is because the GO pedal is out of adjustment.
If the tractor is creeping forward I tap the reverse pedal very lightly and it stops... maybe an internal seal.
   / Is this normal on Kiotis? #22
Mine has crept from day one in 2012. I do what Scrambler does and all is good.
   / Is this normal on Kiotis? #23
Hydro's creep on level ground because the swash plate is not centered. In other words the plate is not coming back to a neutral position.
   / Is this normal on Kiotis? #24
That's the one....I just could not get to taking a pics......thanks for adding that....let's see what OP says now....
For some reason my tractor will not take pics either!
:D
   / Is this normal on Kiotis? #25
   / Is this normal on Kiotis? #27
Aha! James, thanks for this. :thumbsup: I've done it from time to time for years, but never drilled down to learn the technical explanation for why tapping the pedal for the opposite direction works.
Just pulled up this interesting tutorial: https://isavetractors.com/articles-1/tractor-science-the-hydrostatic-transmission/
They didn't really show that the 9 pistons rub on the swash plate or "slip". Of course the whole thing is immersed in oil, but wear does occur. In our smaller SCUTS and up to a point on larger CUTS the swash plate is controlled directly and mechanically by the pedal system Above a certain size the force on the operators foot required to move the swash plate increases to an uncomfortable level, and then they employ a hydraulic or electric/hydraulic servo mechanism to indirectly move the swash plate. Of course anything can get out of adjustment and not center perfectly so that the swash plate has some "bias" toward one side of the other.
UNUSED WOLVERINE TDB-11-78W 78" BUCKET (A57193)
UNUSED WOLVERINE...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
