Backhoe Is this Long Backhoe worth it?
/ Is this Long Backhoe worth it? #1
teg
Super Member
nowhere
s
Thanks to all those that answer questions.... I'm looking at buying a Long Backhoe (not sure of model #, other than it's old), of course the price is right, $700. I'll test dig with it in the morning but it goes on a big (70hp, cat 2) JD. It has it's own PTO pump, but I wonder if my Kubota L2800 w/ FEL would be able to pick it up. I plan to look into the reinforced top link and would love to get a subframe for it. I would have to guess it might have to be fabricated.
http://www4.ncsu.edu/~dmott/farm/backhoe/
Hope the link works, I'll attach a photo, just in case.
/ Is this Long Backhoe worth it? #2
$700 jump on it you can beat that thing to death and it won't owe you a dime. I think with a little maintenance you will get a lot of service out of it Gary
/ Is this Long Backhoe worth it? #3
I would say that if it works, it is well worth $700. I would also be very careful using it on your Kubota without a subframe, if it was meant for a large tractor it could easily have the power to do serious damage to the 3ph/castings of your smaller tractor if used to aggressively.
Thanks Bully, I understand it's a good price but if it's too heavy for my tractor and breaks the 3ph.... then it's not such a good price. The reach of this backhoe is over 10ft, and that might be too much weight for my L2800.
This is my first (& last) tractor and I have not planted my money trees at the farm, yet. So, if the tractor breaks, I'm digging the rest of the stumps by hand. /forums/images/graemlins/frown.gif
I'm going to try it out this morning, if everything works, I'll load it up and worry about a subframe next. Anyone have closeup photos of how a subframe and backhoe mate? Would a Kubota subframe work with any 3ph backhoe?
/ Is this Long Backhoe worth it? #6
I can tell you that a neighbor of mine has one of those BHs mounted on a very old Massey. I've used it myself and it's a very capable BH. Used it to clear a portion of our property and dig the stumps for a pole barn. I would jump on it for that kind of money.
/ Is this Long Backhoe worth it? #7
Hey there ,
with the purchase price that low you could buy a 4 pnt woods frame and a good welder could refit that to it and your worries would be over. even with a toplink reinforcement i would be nervous about damage with a frame refit you could have more confidence operating. I don't like spending other peoples money for them but thats a suggestion
kman
/ Is this Long Backhoe worth it? #8
I've had the same model for about 8 years. I originally had it on a Ford 800 with a homemade subframe that attached to the loader frame. This year I traded to a DK45S Kioti & adapted the backhoe with a Woods 4 point subframe. I ran off the tractor hydraulics on both tractors. You shouldn't have any problem with the JD 3 pt hitch. On smaller tractors its the tractor frame that is vulnerable to stress. Many have broken at the clutch housing with 3 pt. backhoes. If nothing else buy it, weld on brackets to match a Woods subframe (2 pieces of 1/2' x6" x20") & sell it for $2 grand. I also have a Case 580 and keep the Long for small jobs in tight quarters and for home use when the Case is on a job. I'd want a good price to part with mine.
/ Is this Long Backhoe worth it? #9
Go to the Woods website and look for the owners manual for the subframe that fits your tractor. From there the fit up will be obvious.
/ Is this Long Backhoe worth it? #10
Teg - This really has nothing to do with subframe mounts or answers any of your questions. What did impress me is that this backhoe has been sitting for who knows how long and the hydraulics have not bled down. That alone should be worth the money in hydraulic cylinders, controls, and pump. From a practical standpoint, you might have to spend a few grand to get you setup with a subframe mount but you are still way ahead compared to a new backhoe.
Keep us posted and best of luck to you - Clyde
Since 5 people wanted to buy it from the farmer - sight unseen, I figure if it doesn't fit the tractor, I'll re-sell it. It was last used 2 years ago, the fact that it's still standing is because of some braces (see photo). We had to pour 2 gallons of fluid in it but it worked fine. A little "loose" but that comes with age (may add some washers).
Talked to a Kubota guy down there that knows the backhoe & he said it would flip the L2800 in a heart beat. We hooked the BH up to the farmers JD tractor - boy is that thing TALL! Right now our plan is to mount it to a little Nortrac 30hp Bulldozer. The BH is a Cat 2 but I have the pins to "make" it a Cat 1....
Thanks all for the encouragement to buy!!!
Bulldozer photos, more fun than tractors
More backhoe photos....
To give you a little scale for how tall the BH is, I think it was a 65hp JD (2640?, my memory is not what it used to be).
/ Is this Long Backhoe worth it? #13
I'm just now seeing this thread, but I have one like it. It's a Long model 1199. To me, the controls are too sensitive. I run it at about 1000 engine rpm and can't move the swing controls slow enough to prevent it jerking, same with the main boom. If I run any less rpm it doesn't have any power. The dipper boom and the bucket controls work fine. I use mine on a Case-IH 385, about a 35 pto HP tractor that weighs 5000#. I wouldn't want to put it on a lighter tractor.
Yes, I agree it's too fast and it swings back & forth before it "stops" (more so, since it's old) also you move with the boom.... It's like a ride at the fair /forums/images/graemlins/smile.gif
In the back of my mind, I think.... "If I'm really careful and slow and don't push it, maybe it will work fine with the L2800". In the front part of my mind, "I'm going to break the tractor and will be out of luck", /forums/images/graemlins/crazy.gif (as of now, I do NOT plan on putting the BH on the L2800, subframe or no subframe).
The small bulldozer is 6000# but I'm still worried about the 3ph (it may break, too). I only need to do a couple of projects (famous last words), so previously, I had decided to just rent one ($6-700/week). So if I can get what I want done (slowly), I'll have saved money by buying this. /forums/images/graemlins/cool.gif
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
