Is this amount of oily dirt normal w/a backhoe?
   / Is this amount of oily dirt normal w/a backhoe? #11
Does not look normal to me for those hrs . It may not be the cylinders , possibly a hose or connection fitting . Beware of a high pressure leak , could cut right through your skin . Good luck
Dk40SE
Another ditto. My KB2375 doesn't look like that. For the most part it's dry of oil grime except at the pivots where you grease the zerks. If it's "misting" as mentioned, then you have small leaks somewhere.
   / Is this amount of oily dirt normal w/a backhoe? #12
X3, but to me, it looks like it is coming from the valve/ hoses near the valve.
   / Is this amount of oily dirt normal w/a backhoe? #13
What was said about hr. meter and hours/paint condition, general level of grease/grime, not equated with 160 tractor hours on a new tractor. If you want the tractor as part of a land deal, I'd say take it- depending what it is valued at in the deal.
Send us a pic of the entire tractor, showing engine, seat area etc. and we may be able to better comment on its 'value' to you. If you want to find the source of the 'misting', read LEAK, use some gunk or grease cleaner and spray the area in question, hose off and then run the unit until you see where it is building up grease/hydraulic fluid first. Use a piece of cardboard to see if the leak is evident on it. DO NOT use you hands, even with gloves- hydraulic pressure will allow fluid to inject into your skin and can lead to need for immediate surgery in best case. All leaks are repairable- just depends on where it is as to time/cost of repair.
Good luck! Post back....
flooring (A55758)
flooring (A55758)
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
Portable Restroom (A54865)
Portable Restroom...
2013 Ford F-150 (A55973)
2013 Ford F-150...
