Is this a good compressor?
/ Is this a good compressor? #2
You'll get lots of responses on this, I think. It looks like an oil-less design, which are generally louder than oil-filled compressors, and require periodic rebuilding. I bought a unit with similar capacities (Husky) that was oil-filled. It is much quieter than the oil-less compressors I have heard and runs about $369.
If you don't mind the extra noise, I'm sure that unit will run a paint gun and all sorts of other things. I love having a compressor available. It is so handy.
/ Is this a good compressor? #3
I purchased this Sears 60 gallon standalone compressor. I got it at the store, on sale, and used my Craftsman Club discount plus a one day 10% off discount plus another discount coupon I had. Total came to $345. I have no complaints concerning its operation.
Sears 60 gallon compressor with oillube pump
/ Is this a good compressor? #4
Bear in mind that the 6hp is a phoney peak hp rating. There has been a class action lawsuit about this in the small portable compressors but I don't think Sears was a party to it. The "real" hp is probably 1.5 to 2. I don't remember what the ratio is.
Vernon
Well my old little pancake sear compressor gave up after only 15 years of abuse I mean use.
Anyhow I have to replace it and may have/wamt to repait my 78 chevy truck so I want one that is up to running a DA sander and a paint gun and so on
/ Is this a good compressor? #6
I bought basically this same compressor almost 2 years ago, except that I got the horizontal tank. Easier to move it around. I've had no problems with it, except the drain valve leaking off. Sears immediately sent out a new one, I've since replace that with a ball valve to allow for easier draining as well as faster draining, it seems to remove more moisture. I use a palm nailer, framing nailer, 3/8" impact, 1/2" impact, 3/8" rachet, brad nailer, and a pneumatic grease gun. Dad even used to with a die grinder a couple of times when we were doing something. I think he had to stop a time or two because the pressure had dropped, but nothing terrible. It has been a great asset to have around the house. Would I want to run a tire business or a body shop on this compressor? No, but for average home use it is a great little unit. As far as noise, my oil-less isn't any louder then my F-I-L 's oil compressor (brand unknown).
/ Is this a good compressor? #7
We bought an upright 60 gallon CH w 5hp motor at TSC for 37x.00
I've seen imports at the chineese store for a tad cheaper.
Homier traveling show sometimes has a 299 one.
Soundguy
/ Is this a good compressor? #8
BTW, I think between coupons & % offs, we were able to get my for around $230 at the time. Wife is really good at working deals between coupons and such.
/ Is this a good compressor? #9
Running DA's or any other type of air tools requires a lot of air. I've tried the 5hp 30 gallon type with no success. You will need a two stage unit if you are going to be using air tools for any long amount of time. The smaller compressors have a lousy recovery rate. You can check the rates by comparing the tools to the rate of the compressor. I now have two large compressors. One for my barn next door and one in my garage at home. The Garage has a vertical 6HP 80 gallon two stage from BJ's Discount. The barn compressor is a much older rebuilt American Kellog 5HP 80 gallon horizontal that wieghts about 700 pounds or more. It is also a two stage with cooling lines and an enormous motor. I think the BJ's one cost me around $800.00. I have it set at 175psi. It is 200 psi rated. It never runs out of air no matter what tools I run with it. The barn compressor is an industrial unit that I paid $700.00 for back in 1978. The compressor head and motor were just rebuilt on it before I bought it. This unit is twice that of the BJ's unit in power and recovery rate. Both units have been trouble free since I bought them. Go bigger than what you think you will need. You can't go wrong that way.
/ Is this a good compressor? #10
I have the horizontal Sears one also, and have been very happy with it. I just use it for repairs around the farm, but I also used it to run a framing nailer on building an extension on my house, and it ran perfectly. With moderate use, I've never had a problem with it. I've had it for three years.
/ Is this a good compressor? #11
Yes, Chuck, at 8.6 SCFM @ 40 psi and 6.4 SCFM @ 90 psi, it'll fun your paint gun and most of your other tools, but as has been mentioned, the oilless is a pretty short lived compressor if you run it a lot. At the very least, avoid running it continuously for more than 10 minutes.
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2019 F150 (A61306)
2019 F150 (A61306)
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
