Is there such a thing as reasonably priced front weights?
   / Is there such a thing as reasonably priced front weights? #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I would like to buy some front weights for a new six series JD. Is there anyway to get them for a better price than new fom dealer?
   / Is there such a thing as reasonably priced front weights? #2
Craigslist?
   / Is there such a thing as reasonably priced front weights? #3
EverythingAttachments.com has aftermarket copies of JD weights. Number 4015 100lbs, Ten for $959 with free shipping.
   / Is there such a thing as reasonably priced front weights? #4
Good luck, even used ones around here are $1 a pound. This company sells aftermarket one, but after shipping there is no real savings: Lonestar Weights & Castings
   / Is there such a thing as reasonably priced front weights? #5
what he said ^^^ When I was looking it seemed they were all close to the same... new, used, aftermarket, etc. Unless you get lucky and find a good deal on some used ones, you're probably best off going to the dealer.
   / Is there such a thing as reasonably priced front weights? #6
Most small weights seem to be a $1.15-1.25 a pound. I went with aftermarket weight to save a little money on the BX.
   / Is there such a thing as reasonably priced front weights? #7
While I don't know the 6 series Deere, lots of Deere front weight brackets will accept earlier Deere weights from other series. For my 5520 I've got weights off earlier and different model (1970's?) that fit and work fine. It's their typical 100 lb weight and I bet it will fit yours as well and those weights are commonly available.
Short of that, you just have to suck it up and pay for them. When it comes to weights I just write a check and forget about it.
   / Is there such a thing as reasonably priced front weights? #8
Example from CL today:
John deere tractor weights - $75 (Cecil county)
I have two 40lb tractor weights that I don't have any use for
Their in great shape!
Text or email 443 *** ****
it's NOT ok to contact this poster with services or other commercial interests
   / Is there such a thing as reasonably priced front weights? #9
If it has a loader - and if the loader isn't enough, put a LOAD in the bucket.
   / Is there such a thing as reasonably priced front weights? #10
I was just thinking the same thing. Why not just pick up a granite basketball or two? When you're done with them, dump 'em.
MIDEA 8000 BTU WINDOW AC UNIT (A51248)
MIDEA 8000 BTU...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2022 UTILITY FS2CHA 48FT FLATBED TRAILER (A53426)
2022 UTILITY...
40ft Shipping Container (A52377)
40ft Shipping...
JOHN DEERE 560M LOT IDENTIFIER 15 (A53084)
JOHN DEERE 560M...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
