Is There Source Out There for Retaining Clips
   / Is There Source Out There for Retaining Clips #1
craigermags
I am looking for a source to buy some retaining clips that holds that two parts of my tractors air filter together . I have attached a picture of it. Can anyone help me. Thanks Craig
   / Is There Source Out There for Retaining Clips #2
Junkyard?
McMaster has the material to make one. Too bad the minimum length is 25'.
McMaster-Carr
   / Is There Source Out There for Retaining Clips #3
Have you taken a sample to a large automotive supplier/wholesaler..
   / Is There Source Out There for Retaining Clips #4
How about the dealer for your machine?
Thanks for you input on this. The manufacturer of my machine no longer makes this part. I have considered going to NAPA to see what they may have. I have also been in touch with an automotive parts dealer called Restoration Specialties & Supply, Inc. which has something like I need but not quite.
I think in the end I will have to just fabricate something myself buy using some kind of spring steel clip I can find at an automotive store or maybe home depot or my local hardware store.
Craig
   / Is There Source Out There for Retaining Clips #6
I am assuming that is a spring steel latch . You mght try a company like Donaldson who make a lot of the air filter assemblies for trucks and equiptment.
Bill
   / Is There Source Out There for Retaining Clips #7
If the retainer doesn't have to be a replica make one out of a coil spring with a clip at either end. :D
Duct tape??
   / Is There Source Out There for Retaining Clips #8
My Kubota air cleaner has clips like these, might try a Kubota dealer.
   / Is There Source Out There for Retaining Clips #9
Try forming some clips using steel strapping (like what they use to strap lumber) .
It can be bent cold to a certain extent but also can be heated with a plumber's torch to get desired shape.
Good luck!
   / Is There Source Out There for Retaining Clips #10
My 2007 Honda ATV has very similar clips for air cleaner,
go to a Honda parts desk and bring your pic I bet they have one close in stock.
jake
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
Komatsu PC138 (A50490)
