Is There Source Out There for Retaining Clips
   / Is There Source Out There for Retaining Clips #1
craigermags
I am looking for a source to buy some retaining clips that holds that two parts of my tractors air filter together . I have attached a picture of it. Can anyone help me. Thanks Craig
   / Is There Source Out There for Retaining Clips #2
Junkyard?
McMaster has the material to make one. Too bad the minimum length is 25'.
McMaster-Carr
   / Is There Source Out There for Retaining Clips #3
Have you taken a sample to a large automotive supplier/wholesaler..
   / Is There Source Out There for Retaining Clips #4
How about the dealer for your machine?
Thanks for you input on this. The manufacturer of my machine no longer makes this part. I have considered going to NAPA to see what they may have. I have also been in touch with an automotive parts dealer called Restoration Specialties & Supply, Inc. which has something like I need but not quite.
I think in the end I will have to just fabricate something myself buy using some kind of spring steel clip I can find at an automotive store or maybe home depot or my local hardware store.
Craig
   / Is There Source Out There for Retaining Clips #6
I am assuming that is a spring steel latch . You mght try a company like Donaldson who make a lot of the air filter assemblies for trucks and equiptment.
Bill
   / Is There Source Out There for Retaining Clips #7
If the retainer doesn't have to be a replica make one out of a coil spring with a clip at either end. :D
Duct tape??
   / Is There Source Out There for Retaining Clips #8
My Kubota air cleaner has clips like these, might try a Kubota dealer.
   / Is There Source Out There for Retaining Clips #9
Try forming some clips using steel strapping (like what they use to strap lumber) .
It can be bent cold to a certain extent but also can be heated with a plumber's torch to get desired shape.
Good luck!
   / Is There Source Out There for Retaining Clips #10
My 2007 Honda ATV has very similar clips for air cleaner,
go to a Honda parts desk and bring your pic I bet they have one close in stock.
jake
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A51039)
DeeZee Crossover...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
100GAL L SHAPED FUEL TANK (A50854)
100GAL L SHAPED...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
