Is there any way to quote quoted material when using "reply with quote"?
   / Is there any way to quote quoted material when using "reply with quote"? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Is there a way to get what is between the html tags in a "reply with quote"?
Presently it seems the forum software discards anything wrapped in html quote tags.
Thus some members are posting stealth quotes, using color tags to insert their writing into previous posts. Thus to accurately quote their message one must go back and cut and paste.
For example if one does "reply with quote" to this post the text:
"Presently it seems the forum software discards anything wrapped in html quote tags.
Thus some members are posting stealth quotes, using color tags to insert their writing into previous posts. Thus to accurately quote their message one must go back and cut and paste."
does not show up before where I wrote "For example".
   / Is there any way to quote quoted material when using "reply with quote"? #2
Re: Is there any way to quote quoted material when using "reply with quote"?
outer
Re: Is there any way to quote quoted material when using "reply with quote"? test test test test
outer
Yes, you can stack quotes: [ quote ] outer [ quote ] inner [ / quote ] outer [ / quote ] (remove spaces and change to capitals for "quote"
I know that.
But for example I clicked reply with quote to your message and all it quoted is what's above
instead of: quote.JPG
And I don't have to
capitalize the q in quote.
   / Is there any way to quote quoted material when using "reply with quote"? #4
NO! :laughing:
I think you're asking how to quote the person you're replaying to, AND get any quotes that they may have made in the post that you are replying to, correct?
   / Is there any way to quote quoted material when using "reply with quote"? #5
I know that.
instead of:View attachment 534248
And I don't have to
When you hit reply with quote it will quote what the person wrote, not the quote they were replying to, that you will have to copy/paste manually. That is a royal pain when someone has 15 lines of colored text replies inside someone else's quote...
Aaron Z
NO! :laughing:
You've got it :(
Aaron Z
Thanks, I didn't know if there was some option unknown to me, like when I recently was pointed to the " Automatically parse links in text" flag.
Thanks.
   / Is there any way to quote quoted material when using "reply with quote"? #8
Some Other Guy said:
Quote Originally Posted by aczlan View Post
Aaron Z
Thanks.
Yep. You can just highlight the whole post, CTRL+C to copy, reply to post, CTRL+V to paste, then put as many quotes as you want in there with the brackets and quote /quote and make it look anyway you want.
   / Is there any way to quote quoted material when using "reply with quote"? #9
I know that.
And I don't have to
One way is to use the "view post" to go to the original, then use the "multi-quote" to pick it and the secondary message.
2103 (A58376)
2103 (A58376)
2022 Behnke Trailer (A55973)
2022 Behnke...
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
2022 Deere 325G (A57148)
2022 Deere 325G...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
