Is there any kind of intermittent 12v beeper?
   / Is there any kind of intermittent 12v beeper? #1
bdog
Elite Member
Texas
John Deere 6130M
Is there any kind of 12 volt beeper/buzzer that can make a subtle noise every five minutes or so when energized?
I have a 12v fuel transfer pump that pumps fuel from the transfer tank in my pickup bed into the pickup痴 main tank. It is a slow pump and takes about an hour to fill and sometimes I forget it is on and overfill my tank causing minor spills out the vehicle fuel tank cap.
Normally I use this tank and a traditional fill-rite pump to fuel my tractor and equipment but when on long road trips, particularly when towing I use the small pump to extend my pickup痴 range without stopping. I just flip the switch and then have to shut it off before the tank is full.
I was thinking if there was a beeper of some sorts that makes a sound every five minutes or something it would remind me it was on and to shut it off before the tank overfilled.
   / Is there any kind of intermittent 12v beeper? #2
Easy thing would be go to Wal-Mart or a dollar store, and get a 60 minute timer, either digital or wind up, and be done
   / Is there any kind of intermittent 12v beeper? #3
Set a timer on your phone
   / Is there any kind of intermittent 12v beeper? #4
You could attach a flashing led or similar, should do the trick if in your field of vision
   / Is there any kind of intermittent 12v beeper? #5
Google: Relay timer buzzer.
Something like this seems like it would work, although the description seems it is written by someone who speaks English as a third language.
https://www.amazon.com/Infinite-Switch-Module-10-1400-Seconds/dp/B07MV4YH9H/ref=asc_df_B07MV4YH9H/?tag=hyprod-20&linkCode=df0&hvadid=309793588525&hvpos=1o2&hvnetw=g&hvrand=4805062648975451743&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004825&hvtargid=pla-671686575564&psc=1&tag=&ref=&adgrpid=60862048759&hvpone=&hvptwo=&hvadid=309793588525&hvpos=1o2&hvnetw=g&hvrand=4805062648975451743&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004825&hvtargid=pla-671686575564
The 12V pump power, would be the same "input power" to this relay that, whenever the pump is running, initiates the on/off timer functions that would switch a separate buzzer (not included) that is wired through the normally open (N.O.) and common (COM) contact (switch) of this relay .
It sounds like you can set the switch to the buzzer to close if the input power has been on (same power as pump running) for (say) 5 minutes, and then set the buzzer to turn off 5 seconds later, and then repeat this cycle as long as the input power (pump running) is present.
   / Is there any kind of intermittent 12v beeper? #7
More like 4th language. Something is really lost in that translation from Mandarin.
:thumbsup: ......but they probably do a whole lot better job than if you or I had to write a description in Chinese !!
Thanks guys.
While a timer on my phone or a wind up timer might work I would have to remember to turn it on. It also isn't like it is an exact fixed time amount I need the pump to run. I have a very good filtration setup between the transfer tank and the pickup tank and I try to pump all fuel into the transfer tank first and then into my truck and am often flipping the pump off and on.
   / Is there any kind of intermittent 12v beeper? #9
You do have a point. :)
   / Is there any kind of intermittent 12v beeper? #10
Actually, for a description from a Chinese supplier on Amazon that isn't bad, I've seen way worse!
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A52748)
2020 Westfield MKX...
