Is there any hardware to slide a tube gate?
   / Is there any hardware to slide a tube gate? #1
petebert
Outside of Ann Arbor
I don't need a full paneled standard barn door. Right now I'm sliding this gate back and forth along the ground. Wondering if any hardware exists to do something like this and make it smoother? I've tried googling it but now that everyone is putting barn doors in their house, that's all the results I get.
   / Is there any hardware to slide a tube gate? #2
You may have to fabricate something but I had a friend who used a bicycle wheel for the purpose. Harbor Freight has some inexpensive wheels which can use standard size rod for axles. If you have a bit of mechanical know how and some scrap steel lying around you can probably fabricate a means of attachment.
   / Is there any hardware to slide a tube gate? #3
Check rolling gate hardware, that should give the items you'll need.
   / Is there any hardware to slide a tube gate? #4
What is the reason that you do not use a hinge?
   / Is there any hardware to slide a tube gate? #5
I swear I've seen some big rollers (pulley like shape) that you mount atop and below the tube gate to sorta pinch and suspend it.
   / Is there any hardware to slide a tube gate? #6
2 3/8" gate rollers are what you need. They're everywhere, shocked no one else has used them as think even home depot carries them and the local place has a bucket full.
   / Is there any hardware to slide a tube gate? #7
Use a barn door rail and one hanger on the inside just above the gate. Lift one end and roll it open or closed.
Bruce
   / Is there any hardware to slide a tube gate? #8
drill a 1/2" hole thru the end of the gate tubing. get a couple wheels with hubs for 1/2" axle. put 1 wheel on each side of the gate ,cotter pins in the ends of a piece of 1/2" inch bar stock.
or
use a long 1/2" bolt and lock nut the threaded end.
probably under $30.00 total
   / Is there any hardware to slide a tube gate? #9
One of the gates at work is on rollers that are mounted to the posts. The gate doesn't have any wheels on the bottom, just sets of rollers for guides and support. It looks like the sketch under #1 in the link below and the opening is probably 15 feet or more in width.
   / Is there any hardware to slide a tube gate? #10
Bruce
i like this idea. Except I would consider running the rail over the full length up high. Then dropping 2 chains down to the tube gate (one each end). Of course some channel to keep the gate in position when the wind blows, etc. A solid receiver bracket for the left end as well.
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55302)
Galvanized...
Step Ladder (A47477)
2020 Ford F-350XL (A53314)
2020 Ford F-350XL...
