Is there a way to get a first fix on the water level in a tractor's tires?
   / Is there a way to get a first fix on the water level in a tractor's tires? #11
Rotating the tire is the most accurate if you are in a climate where you can't see the dew line in the right weather.
   / Is there a way to get a first fix on the water level in a tractor's tires? #12
A sharp pointed object would work also. Just punch a series of holes in the sidewall until water is noted running out instead of air.
The tyre will be useless, but at least you'll know how much water was in it.
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
2019 Bobcat 3400 4x4 Utility Cart (A55851)
2019 Bobcat 3400...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
(49) 2" X 3" X 19" TUBING (A54756)
(49) 2" X 3" X 19"...
