Rear Blade Is there a way to adust the lift arms to lift higher?
   / Is there a way to adust the lift arms to lift higher? #11
You are welcome and the TBN,r that had trouble with the linkage was MIDGALandscaper. Had a plow just like mine.
   / Is there a way to adust the lift arms to lift higher? #13
You're right. I re-read the post and misunderstood. Thank you
I did a quick google search for a pic but didnt find one last night. A pic is worth a thousand words ;)
you can see the addtional hole that allows you to raise the 3pt arms. the linkage on the back of my NH has 3 holes
   / Is there a way to adust the lift arms to lift higher? #15
Ideally the boom on the rear blade should be parallel to the ground when the blade is setting on the ground. You need to use your top link to do this properly. To get addition lift from the 3pt hitch, the simplest thing to do is to put the top link in the lowest pin location on the tractor end. If your tractor has multiple clevis pin locations in the side links (lift links), then you can use the upper hole to get some additional lift. The problem for you with this is that I don't think that you have multiple holes in the clevises and therefore are limited to the top link pin location adjustment.
good luck ;)
2023 Load Trailer (A55787)
2023 Load Trailer...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
John Deere Gator (A53317)
John Deere Gator...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
