Is there a volume control for the Backup Alarm?
   / Is there a volume control for the Backup Alarm? #1
Spudgunner
Central Idaho Mtns
Kubota BX-23 & Toolcat 5600 D
My TC's backup alarm is loud enough to wake the dead. I've had to (re)kill three zombies since it arrived. I'd like to tone-down the volume a bit. Is there some nice way of doing this that doesn't involve wire cutters? I like the alarm but the volume seems like it could cause an avalanche on level ground it's so loud.
   / Is there a volume control for the Backup Alarm? #2
Can you put something over it like a glove, rag or foam to muffle the sound ?
Jim
   / Is there a volume control for the Backup Alarm? #3
If it is a legally required back-up alarm you'd better not mess with it.
Even if off road you might find yourself in a mess if (somehow) your back-up alarm was shown to not give adequate warning.
The one on my truck is a bit of a shrieker, but the neighbors are shielded from it by my trailer and I try to arrange things so that I don't have to back out much when I leave really early - unless their party was running really late.
   / Is there a volume control for the Backup Alarm? #4
I have one of those on a man lift. The beeper is right where I stand and is a warning when the lift has too much tilt. I use the lift for my own private use. I just put a piece of duct tape over it. Muffles the sound a lot but can still hear it. Tape lasts several months.
   / Is there a volume control for the Backup Alarm? #5
Spudgunner,
The 110 dBs can be annoying! You may consider ripping out the bubble wrap "heat shield" on the underside of your bed (you will find that this will burn to a crisp soon anyhow if not removed)and "insulate" the back up alarm with it. Then buy some real heat shield and insulate the bed.
Steve
   / Is there a volume control for the Backup Alarm? #6
You may consider replacing it with one of the self-adjusting alarms (or just a smaller one). They adjust their volume based on the ambient noise. When I installed one (just a fixed volume one) on my dump truck, I put a cutoff switch so I could turn it off if conditions required it. I taught myself to leave it on unless it needed to be off, not the other way around. I find myself arriving (leaving) sometimes very late (early) so at times it is very beneficial. It is also really nice when you are hooking up to a trailer at night to be able to leave it in reverse so the guy has some additional light from the backup lights without him going deaf.
bjepple
John Deere 6170R (A53317)
John Deere 6170R...
2015 Ford Transit 250 Cargo Van (A53422)
2015 Ford Transit...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
