Is there a TYM that matches the mahindra 4110
   / Is there a TYM that matches the mahindra 4110 #1
coffeeman
Platinum Member
I ordered some parts for my 4110 for my Mahindra. Mahindra dealer PTO gears came with TYM marking on
box. If, in fact, I am thinking right, would it be cheaper to order from TYM or Mahindra for parts?
Cheers....Coffeeman
   / Is there a TYM that matches the mahindra 4110 #2
Perhaps close, but not exact. The 4010 is made by TYM but to Mahindra's specs and with a Mahindra engine. I'd imagine you would need to search it out by specific part numbers for whatever you are seeking.
   / Is there a TYM that matches the mahindra 4110 #3
I thought it has a Daedong (Kioti) engine. How old is the 4010. It could be compare able to the TYM T-450 or if newer the T-433/503.
Yes, it is Daedong engine. Model # is 4110. Owners manual is for 3510 and 4110 with new sheet metal. Horse power, 35 & 41 of course .
   / Is there a TYM that matches the mahindra 4110 #5
Possibly similar to the T350 maybe instead of the 40-50 hp ones I mentioned before. I would ask a dealer. But u might have better luck with mahindra with parts.
   / Is there a TYM that matches the mahindra 4110 #6
After looking at tractor data, the 4110 weighs in around the same weight as the T450 so my guess would be the T450 would be the one. Good luck.
   / Is there a TYM that matches the mahindra 4110 #7
The T400 and T450 will be your closest match for the tractor chassis. TYM used a Kubota and Mahindra used a Daedong which is the biggest difference between the two.
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
John Deere L125H Skidloader (RUNS) (A50774)
John Deere L125H...
2004 Ford F250 (A50515)
2004 Ford F250...
1000 Gallon Fuel Tank W/Pump (A50774)
1000 Gallon Fuel...
