Is there a standard PTO shaft size?
   / Is there a standard PTO shaft size? #21
Bob,
An idea just flashed into my head. How about shutting down the tractor with the PTO engaged? This might keep the PTO brake from working. I don't know if you've tried this yet, or if it will work/w3tcompact/icons/hmm.gif Worth a shot.
<font color=blue>What I am proposing is that you might try to turn the rear PTO with the engagement lever in the middle of its travel and see if that works better.</font color=blue>
Now there's an idea! I hadn't thought of that, which is one of the things which makes this forum so useful!
I'll go out and try this later.. maybe there is a position which lets the shaft rotate freely. That would be the best of both worlds.
Thanks for the idea!
Bob
<font color=blue>How about shutting down the tractor with the PTO engaged?</font color=blue>
This might solve the problem (if, in fact, it is one) of premature wear on the PTO system, but it won't help me get the PTO shaft on when I change implements. I always try to idle way down before shutting down the PTO, but I really don't want to have to back into the garage and let it idle (to cool down) for 5 minutes with the tiller or mower running.. ya know? It's a good idea, though.. but my main problem is getting that ^%$#@ PTO shaft on. /w3tcompact/icons/sad.gif
BTW, I just went out to see if there was a "middle" position on my PTO lever, and I can't find one. No matter where the lever is, the tractor PTO only rotates, grudgingly, a tiny bit. Well, I have an over-running clutch that should show up in a day or two, and I'll see if I like that. I hope I don't have to shorten the PTO shafts on my implements, because there will be no going back except to replace the shaft. I can't imagine that the OVC would be worse, though. At least I'll be able to connect implements without <shudder> having to ask my wife to help. /w3tcompact/icons/smile.gif
   / Is there a standard PTO shaft size? #24
I think if you have ordered the ORC, it will make a heck of a difference. I just wonder why you have to have one to turn the shaft on a tractor with one built inside??
I have one on my Yanmar, but I NEEDED one. I kept running into things......../w3tcompact/icons/laugh.gif
Jerry
   / Is there a standard PTO shaft size? #25
I found the same thing. The PTO brake drags enough that I can't turn the rear PTO on my tractor at all, with the engagement lever in any position./w3tcompact/icons/hmm.gif The brake on yours may be set even tighter than mine if it abruptly stops your PTO driven implements as soon as your disengage the lever. As I posted earlier, I can let my mid mower gradually slow down by just pulling the lever back an inch or two from the engaged position. On my PTO lever I can feel the point where the clutch begins to engage just before the lever is all the way forward. I can't see any real harm to adding the over-running clutch except that you will lose the safety feature of the PTO brake. I don't believe that there is an over-running cluch built into the tractor since there is normally no need for one on an independent PTO. Good luck./w3tcompact/icons/smile.gif
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
