Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors?
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #1
foxman
Ashland, Ohio
JD X758, JD 4400, JD 332, Kubota T1880, Kubota GR 2110, JD H, JD B
When I bought a new JD 4400 Compact tractor I foolishly included a 74 Front Blade, dozer type, and a 66" Commercial 60 Belly Mower. The blade has never been used and the mower only 20 or 30 hours at most. How can I find buyers for these rather unique attachments?
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #2
I'm sure someone will be interested. That stuff is hard to find in that good of condition
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #3
That's not foolish, it sounds smart to me. I wish you were around here. I'd love to find a "used" front blade like that for snow.
But why don't you want to keep it?
never use it...I have a snow blower
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #5
OK. It sounds like you know tractors and know what you want. I assume the front blade has Quick Attach (QA) of some kind. Is the QA a SSQA or the JD proprietary type? Sure is a nice looking blade.....
rScotty
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #6
rScotty
It is the type that mounts to the frame when the loader is not on the tractor.
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #7
Oh, of course it is. That isn't common here & I've been curious how well one would work.
sorry, missed a couple posts. Yes, it mounts to the frame with typical quick-tatch mounts...just like a garden tractor blade or blower, but a bit larger pins. It would be a great little dozer, but is 4-way rather than 6-way blade. A crafty guy might make a belly blade of it, come to think of it. would have to mount at the rear rather than mid-point of a larger tractor...we adapted a JD 43 Center Blade (belly blade), which was for JD 110 through 214 models, to a 332 with full hydraulic control and it is the cat's meow for stone driveways...just like the county maintainer/road grader! you can't get a drive or road flat with a rear blade, of course...seldom have to buy stone! can't believe it's not still made for current tractors. so, here's an opportunity to make your own road grader. (patent not pending)
   / Is there a market for a belly mower and front blade to fit 4200 to 4400 Compact Tractors? #9
Is that front blade compatible with a 955?
It is bolt-on for 4200, 4300, 4400 and the following 10 series - 4210, 4310, 4410. It could be made to fit many other compact tractors, but I can't say what it would take. Basically, you would have to get the blade's four quick-attach mounting brackets (see the photo) onto a tractor and then it's just the four spring-loaded pins to install and remove the blade. It could be made to fit any brand tractor which has two selective control valves. (raise/lower and angle) As I wrote earlier I think m it would make a great belly blade for lane maintenance if fabricated to mount on a larger tractor such that the mounts would be towards the rear and the blade underneath where the mounts would be for a front blade. Anybody near enough to north-central Ohio want to give it a try?
John Deere Z915E Zero Turn (A51573)
John Deere Z915E...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
