Is there a knowledgable dealer/rep on the forums?
   / Is there a knowledgable dealer/rep on the forums? #1
robertwhite
I have a CT335 and am trying to figure out if the backhoe pictured here will work. A "maybe" won't cut it as I don't want to buy it and then be stuck with a piece I can't use.
Unfortunately, this is the only photo I can get.
   / Is there a knowledgable dealer/rep on the forums? #2
There is a gentleman named Rick Wallace that is on this forum...He is a Knowledgable dealer and a very helpful human being as well. I hope he will chime in here soon.
   / Is there a knowledgable dealer/rep on the forums? #3
Do you have a make and model for it?
Aaron Z
   / Is there a knowledgable dealer/rep on the forums? #6
Certainly looks like it runs off the three point hitch and the PTO. Do you plan to run it that way or do you want a frame mount. As it sits, I would think it can be run off any tractor with a 3pt hitch and pto, but no one recommends that set up anymore, especially Wallace. Too many problems with the BH tearing up the top link connection. I had one for years on a Chinese tractor and had no problem, but it was all pretty light duty stuff that I used it for.
   / Is there a knowledgable dealer/rep on the forums? #7
Okay..okay...I'm here!
That is a Woods backhoe. There is no mount that will "bolt right up" to your tractor.
Now I am going to give you a little piece of advice..A customer of mine did just this a little while back. He purchased a used Woods backhoe "good deal" and after spending thousands of dollars on repairs and a subframe mount. He would more than likely tell you not to bother with this.
He purchased a used Woods 7500 which had a direct bolt on subframe.
This one does not, nor does Woods have a subframe to bolt to the CT335 with out a little fabrication.
Unless you are practically getting it given to you, you may want to move on. Chances are you will be dropping a couple more grand to get it safely on your machine.
I have some brand new Rhino CB85's in stock. I will sell you one w/subframe and bucket for $6,500
Thanks. That's all I needed to hear. I will definitely not be bidding on this one.
2022 Coras Predator Steel End Dump Trailer (A56435)
2022 Coras...
14C SCRAPER (A58214)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
