Is There A Good Use For Sweetgum Saplings.
   / Is There A Good Use For Sweetgum Saplings. #1
TBAR
Texas
IH2444 & 1949 Farmall Cub
One of our fields hasn't been worked in over 20 years. It is now over grown with Sweetgum saplings. They are so thick you can't walk through them, measure in size from 2"-6" in diameter and are 8-12 feet high.
What can be done with about 100.000 Sweetgum saplings???
TBAR
   / Is There A Good Use For Sweetgum Saplings. #2
Several years ago a friend was looking into growing mushrooms for the market and if I recall correctly sweetgum logs were used for the growing medium. I doubt that yours are large enough, even if there was a market. That's the only use that I've ever heard of for them.
I had the same problem that you're experiencing on my place in MS and found that the toothbar on the FEL will generally take them out with little resistance. Privet hedge was rampant in there as well, but like the sweetgum the roots were pretty shallow. I uprooted them and pushed into piles. The problem with this approach is that it's difficult to work around desirable trees that are growing within the problem areas.
   / Is There A Good Use For Sweetgum Saplings. #3
I know your pain. Those sweat gums will take over in just a matter of months. I've mowed them down, only to come back a few months later and see them 2 feet tall again. Even when you dig them out, if there is any part of the stump still touching dirt, it will continue to grow. I've never seen a tree with such an ability to grow!
The only good thing I can say about them is that they do come out fairly easy compared to the oaks and pines. Only cedars come out easier.
You didn't mention how big the pasture is, but from the size of them, you could rent a small dozer and clean them up fairly quickly. Now the weather is perfect and with the leaves down, you can really see what your doing.
   / Is There A Good Use For Sweetgum Saplings. #4
I you're into crafts, I suppose you could turn some of them into rustic furniture for your porch or deck.
Chuck
   / Is There A Good Use For Sweetgum Saplings. #5
If pasture is large enough, aerial spraying might be cost efficient. Then do a prescribed burn or let them rot. Gums that size decay rapidly.
   / Is There A Good Use For Sweetgum Saplings. #6
It's a shame, the sweet gum is one of my favorite trees. Beautiful fall colors, interesting habit, and those cool spiny pods.
But I realize that any tree you don't want in a particular spot is a nuisance.
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
2020 INTERNATIONAL LT625 TRI AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
WB Mower (A50120)
WB Mower (A50120)
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
