Is there a "correct" way to remove a light bulb?
   / Is there a "correct" way to remove a light bulb? #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
For 26 yrs, I have replaced light bulbs in our present home when they go bad. Then 1 day this summer we had a lady come over and help with some odd jobs in the house. She twisted off 3 bulb bases in the sockets in one day. All I can figure out that caused this, is, that I put inward pressure on the bulb while screwing out. Is it common removal procedure to just grab the bulb and turn left? I told my wife that I was 0 for 26 years and 2 women were 3 messed up in 1 day. She really did not think that was funny! LOL Ken Sweet
   / Is there a "correct" way to remove a light bulb? #2
I bet she was trying to hold the light bulb in place and rotate the house.:confused2:
Did the bulbs or sockets show signs of oxidization?
   / Is there a "correct" way to remove a light bulb? #3
Lefty losey? But a potato stuck in the base after the bulb portion will remove the base most of the time, but pliers needed if that won't work.
   / Is there a "correct" way to remove a light bulb? #5
Was she blonde?
   / Is there a "correct" way to remove a light bulb? #6
I don't know if this is relevant, but I wipe the bulb screw base with WD40 before I install it. Over the years I've had a couple bulbs be heck to remove. Now there is no problems and no squeaking when their going in or out.
No signs of oxidation. The potato and wd-40 are a good idea, however, I used a pair of snap ring pliers to remove. She was blonde for sure. Ken Sweet
   / Is there a "correct" way to remove a light bulb? #9
What? No one blamed the "Chinese" bulb!
UNUSED FUTURE CAT305 EXCAVATOR RIPPER (A58376)
UNUSED FUTURE...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
2016 Kubota L2501 (A57148)
2016 Kubota L2501...
JMR 48x96 Work Basket (A57149)
JMR 48x96 Work...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
