Engine Model | Branson A1700N6 IDI |
Aspiration | Natural |
Emissions Standards | Tier 4 |
Engine Gross Power | 24 hp (18 kW) |
PTO Power | 21 hp (15.7 kW) |
No. of Cylinders | 3 |
Displacement | 104.5 cu.in (1,714 cc) |
Rated Revolution | 2100 RPM |
Fuel Tank Capacity | 7.1 gal (27 L) |
Air Cleaner | Dry Element |
Alternator – 12 Volt amp | 50 |
Wheelbase | 65.7 in (1,670 mm) |
Overall Length (W/ 3PT) | 120.9 in (3,071 mm) |
Min.Overall Width | 56.3 in (1,430 mm) |
Overall Height (W/ ROPS) | 97.3 in (2,471 mm) |
Ground Clearance (4WD) | 14.4 in (366 mm) |
Min.Turning Radius (W/ Brake) | 7.51 in (2.29 mm) |
Weight (W/O Front Weights) | 2,969 lbs (1,347 kg) |
The 2515 is 500+ lbs heavier than the L2501. That is about 25% more.Branson makes a slightly heavier compact tractor with < 25.479 horsepower.
BRANSON 2515H
BRANSON 2515H DIMENSIONS
Engine ModelBranson A1700N6 IDI AspirationNatural Emissions StandardsTier 4 Engine Gross Power24 hp (18 kW) PTO Power21 hp (15.7 kW) No. of Cylinders3 Displacement104.5 cu.in (1,714 cc) Rated Revolution2100 RPM Fuel Tank Capacity7.1 gal (27 L) Air CleanerDry Element Alternator – 12 Volt amp50
Wheelbase65.7 in (1,670 mm) Overall Length (W/ 3PT)120.9 in (3,071 mm) Min.Overall Width56.3 in (1,430 mm) Overall Height (W/ ROPS)97.3 in (2,471 mm) Ground Clearance (4WD)14.4 in (366 mm) Min.Turning Radius (W/ Brake)7.51 in (2.29 mm) Weight (W/O Front Weights)2,969 lbs (1,347 kg)
However, it takes a 50% increase in bare tractor weight before an operator can feel a real capability increase. A 10% difference in bare tractor weight is essentially meaningless.
Sit them side by side. The Branson dwarfs the Kubota. It lifts more. It does more work. You are all about weight until it makes the precious orange tractor look bad, then it is meaningless.
The L2501 is the only 4 cylinder in that class that I know of. Honestly, that's it's only pro in my book. Well maybe that and it's not green.
Engine Detail | |
Kubota | |
diesel | |
3-cylinder | |
liquid-cooled | |
Displacement: | 100.47 ci 1.6 L |
Bore/Stroke: | 3.4x3.6 inches 86 x 91 mm |
Emissions: | Tier IV |
Power (gross): | 24.8 hp 18.5 kW |
Fuel system: | direct injection |
Rated RPM: | 2200 |
