Is the 3E series too large for 1 acre?
   / Is the 3E series too large for 1 acre? #11
There are comparably capable machines for far less money if you look at other colors.
   / Is the 3E series too large for 1 acre? #12
Here is my experience with the 3032E. We bought a 5 acre Christmas tree farm in NC. I designed and we built a house plus took down about 150 no good Frazer fir trees and about 200 White Pines but not with the 3032. I bought a Case 580SE backhoe to do all that and to build the house. We bought the JD after the house was finished but not all the earth moving and I moved thousands of yards of dirt. I am still moving dirt and making roads but with the backhoe. I have a bucket and a 6 foot mower plus a landscape rake with a plow on it. I also have a spiked roller and a bunch of other ground leveling equipment I made. Just yesterday I finished putting in two very large drains to drain off some springs and had to move more dirt. Where I can use the JD in all of this is more for finish work, not for rearranging the ground in any way. I can scoop up a little bit of dirt but the lift is just not there and the weight is not there to dig with the bucket. It is fine for disturbed soil. As far as mowing, I get better results with our Craftsman 52" garden tractor but it takes longer. The landscape rake works good and plow for what little snow we have had. Regrading the yard might be a lot to ask for depending on how much you plan to move. We have about 900 feet of gravel driveway and it is wonderful for taking care of that. If you are going to buy new for 1 acre and do light work, wow, the price tag. If I could do it over I would look for used at half the price, maybe even an older one without the nutty computer.
"without the nutty computer"
AMEN !!!!
   / Is the 3E series too large for 1 acre? #13
AMEN !!!!
A little something about the nutty computer you may not know. First of all, "you don't own it", it, the computer program belongs to JD. So you are driving along and a message comes up on the dash that says something but you can't understand it. The rpm's drop to 1500 and you have no power. What do you do???? Call the dealer, that's all you can do. I have found and downloaded most or at least a lot of codes, (I don't know how many there are). With the codes you can figure out a lot but I have watched the mechanic tech work on my tractor and have is computer on it and he is still scratching his head. My first backhoe was an 8N Ford, second the Case580SE and I have torn them apart and could fix anything on them. Now that my JD is out of warranty it scares the heck out of me. I'm still looking for a good repair manual at a reasonable cost, not $300. Go for an older tractor that has no computer that you can fix plus get a bigger one, you will need it.
   / Is the 3E series too large for 1 acre? #14
I have found with landscaping that involves moving dirt that a used 5' rototiller works great for working up a few inches of hard dirt for the bucket to scoop up. Much more even digging vs. trying to dig dirt with a light-weight tractor and bucket. As well, that roto-tilled dirt sprinkles out more evenly than the chunks from FEL digging. just a thought..
My JD 4300 is a perfect size.. and just before the computer was added. This model is rock solid IMO. As well, hard to find a used one on the market.
   / Is the 3E series too large for 1 acre? #15
I read your post again and even though you have 1 acre you talk about your fix r upper. If it were me doing what you are I would put my eyes on a backhoe not a farming tractor. You say you have the mowing capability and you need to create a garden plus move some dirt, a backhoe will do it. The backhoe is a crane for doing things on the house, it digs ditches and will turn over a garden area. I used mine to dig down one foot in a large garden area. I have a ratchet rake I used on the bucket to rough grade it and remove rocks and it was easy to do. I dug a pond with it and it was my source of a crane for house building. My son in law just bought 150 acres in TN nit too far from us and has begged me to sell him the hoe. I won't part with it. My JD id helpless if I need to dig a trench or lift something very high. Just my $0.02. Oh, in looking for a used one for my son in law I found $11,000 will get a reasonable used one. I'm gonna put a link to my building and dirt moving experience, the backhoe did it all. YouTube
   / Is the 3E series too large for 1 acre? #16
Keep away from JD. (I was cutting the grass today and my wife waved me over to the porch to tell me something. I drove onto the driveway and shut down the mower deck, (6 foot) and turned off the tractor. Back to do cutting and I turn around and see the deck hanging at an angle, left side down and right side up. Told my wife, "rock shaft broke" and a few more things I can't say here. This just adds to all the problems I have had with this monster. I get it by the barn and look and I see the left upper arm has fallen off and the shaft is sticking out of the right side. Looking closer I see the left hand bolt is broken and the shaft is ok. I found the bolt head on the tractor but the washer was gone. Lucky me, I has a mm bolt but not high strength and I made a washer. Can you say LEMON, I can).
   / Is the 3E series too large for 1 acre? #17
The 1025R can do a lot more than you think. I have seriously considered purchasing a 1025R as a second tractor, and so i have been researching it the last 2 months. Its an extremely capable tractor. I have seen my neighbor use his 1025R to bush hog a 90 acre field....which took all day, and the same neighbor also maintains a 1200' gravel drive into his ranch. Everything is done slowly, and with patience. But the 3000 series tractor is not too big for 1 acre.
Just asking, is there a typo in the size of the field? If not I am really impressed.
   / Is the 3E series too large for 1 acre? #18
Nope, not a typo on the field size. My neighbor truly cuts a 90 acre field with a JD 1025R and a 48" Frontier Rotary cutter. But actually takes him more like a couple of days. He is retired now, and a funny guy. He calls his loader a "motorized wheelbarrow"
   / Is the 3E series too large for 1 acre? #19
Would there be enough room to turn the 3XXX around?
Unless there is a need such as a business of some sort that needs the capability of that size I would stick to the 1XXX series tractor. I survived with three different homes and 500-700' driveways and dirt moving with a X740 size tractor for years. The 1XXX is way more capable that that X740.
Eventually with a 5 acre home I bought a 3720 mostly because I "just wanted it", but I did find uses for it like moving a couple thousand yards of earth berm and turn it to lawn.
We sold that house and found 18 acres where the 3720 fits very well with all kinds of concrete projects plus hauling and manhandling 18" rocks and hogging 20" oaks out of a 10 acres hilly woods.
I would get the 1XXX unless there are more uses that you described already.
   / Is the 3E series too large for 1 acre? #20
Yes it is too large
UNUSED SDLANCH SDLD25 DUMPER (A58375)
UNUSED SDLANCH...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
