Is Something Eating My Live Oak Tree?
   / Is Something Eating My Live Oak Tree? #1
Bird
Rest in Peace
Corinth, Texas
I have a live oak tree in the back yard that is literally covered in small holes (see the attachment). My wife even mentioned this morning that when she goes outside at night, she can hear something eating on that tree. We have another live oak in the front yard that's about the same size and age and I had to hunt to find only a couple of the holes in it. I checked a bunch of those holes with a small pick and could not find any of them that go all the way through the bark, so I'm hoping it isn't anything serious. I did spray both the live oaks and the 5 Bradford Pear trees with Ortho Max about a week ago in hopes of eliminating any harmful insects. Does anyone have any idea what's eating on this tree or what, if anything, should be done about it?
   / Is Something Eating My Live Oak Tree? #2
I am not any kind of expert on trees or holes, but just a wild remark -- they look a lot like the holes made in our logs by carpenter bees. Do you see any of them (bees) around?
   / Is Something Eating My Live Oak Tree? #3
I have pines that look exactly like that when we get woodpeckers going after bugs. I haven’t figured out if the holes came from the bugs or woodpeckers, but I suspect the woodpeckers.
   / Is Something Eating My Live Oak Tree? #4
Hi Bird. Woodpeckers. We have a tree out front with circles of holes like that. It's not a Live Oak though. More dramatic to see because the bark is smoother. Two trees just like it within twenty feet and very few holes.
I sort of figure the woodpecker is somehow "farming" our tree. The resident woodpecker that makes the holes will leave the tree alone for months, then start back in on it. Tree still seems healthy enough. Sap drips on the corner of our RV though. Not a serious enough offence to take out the woodpecker. /forums/images/graemlins/grin.gif
   / Is Something Eating My Live Oak Tree? #5
I take it back, yours is more dramatic looking. Just took this pic of some of our holes.
Michael
I have not seen any bees or any other insects or bugs on that tree. We do have a birdfeeder hanging from one limb and we've had sparrows, grackles, doves, mockingbirds, and cardinals, but I've never seen or heard a single woodpecker. And my wife really surprised me this morning when she mentioned "hearing" something that she thinks is eating on that tree at night. I guess I'll be going out there with a flashlight to see if I see or hear anything after dark. /forums/images/graemlins/laugh.gif
Michael, the holes in your tree look the same. I've just got a lot more of them.
   / Is Something Eating My Live Oak Tree? #7
Looks like you've been visited by a yellow-bellied sapsucker. I believe they spend the winter in your area, and the summers up north. If that's what made the holes, there's no permanent damage.
   / Is Something Eating My Live Oak Tree? #8
looks like a woodpecker to me...
in the great Northwet we also get thrushes that are a needlenosed hammer type of bug seeking bird.
   / Is Something Eating My Live Oak Tree? #9
Bird,
From what others have said & my online research, it seems the most probable explanation is ...
"Q. Help! Something is boring holes in my silver maple tree. There are four holes at a time in a horizontal line. These holes are a little bigger than a pencil eraser and deep enough that the tree is oozing lots of sap. What could be doing this? Will my tree die? Do I need to plug the holes and with what? What can I do to prevent this from continuing? It has happened three times already! Thanks for any insight you can provide, because I really don't want to lose my tree.
-- Terry Emmons
A. It seems mysterious, doesn't it? There's no sign of an insect, but obvious holes in the tree! The telltale clue is the horizontal pattern of the holes. Boring insects tend to make a random pattern of emergence hole. Only a vertebrate with a brain would systematically make a line of holes. It's probably a sapsucker, a type of woodpecker.
Their strong, pointed beaks are used for digging insects from trees, excavating nesting cavities and for "drumming." Since woodpeckers do not have true "songs," they use sharp calls and perform rhythmic tapping (better known as drumming) with their beaks on surfaces, such as dead tree limbs, metal poles and building siding to attract a mate or announce territorial boundaries. Both male and female woodpeckers drum. It is primarily this drumming behavior that may cause serious problems for homeowners.
The yellow-bellied sapsucker bores neat rows of one-quarter inch holes spaced closely together. Most often, they bore holes on trees rather than structures, since they feed on sap.
Several options are available to you to reduce or prevent woodpecker damage. It is best to make use of several of these non-lethal methods at the same time, as soon as the damage begins.
Woodpeckers can be frightened from the area by scare devices such as banging pots, clapping hands or spraying the birds with a high-pressure water hose. Using high-reflective mylar tape (one-half inch width) has also been successful. Mylar balloons can be used in a similar manner.
You can exclude the woodpeckers by mounting fine mesh netting or screening on the tree or by covering the affected area with heavy (3-plus mm) plastic sheeting. This will keep the birds from being able to grip the rough texture of the tree with their claws. They cannot peck or drum if they cannot hang onto the surface of the tree. This can be put up or removed as needed.
Do not plug the holes since this can trap bacteria and moisture within the holes, leading to decay. Trees heal by the formation of scar tissue. Recent research throws doubt on the value of the practice of painting a wound and is no longer recommended. .."
I've never seen so many holes like that in one tree. At least so far I see no sign of any sap leaking out and I didn't find any holes that go all the way through the bark. I appreciate everyone's responses, and they do make it sound as if some type of woodpecker or sapsucker is doing it. And of course that may be the case. It's just that I find it a little hard to believe they could do so much without us ever seeing one. I mean there are literally those little quarter inch holes from less than a foot from the ground on up the tree to at least 10 feet off the ground, all the way up and out on most of the branches; literally thousands of them. This is not a very big live oak; 27" circumference (not diameter) where the picture was taken about 5' above the ground. I can see up about 10 feet on the main trunk where the holes appear to be more in a vertical line than a horizontal line and so close together that it appears almost like something has just stripped the bark vertically for a foot or more. And that tree is less than 9 feet from the deck in the breezeway; less than 20 feet from where we sit out there and watch the birds at times. Here's a picture from the other side of the breezeway showing the table and chairs where we sit out there and you just see the lower branches of the tree in the upper left corner.
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2016 Nissan pathfinder (A50324)
2016 Nissan...
2008 FORD F-750 (A50854)
2008 FORD F-750...
UNUSED AGT KFE-20 ELECTRIC STRAIGHT MAST FORKLIFT (A51243)
UNUSED AGT KFE-20...
