Tractor Sizing Is my truck big enough?
   / Is my truck big enough? #1
tripppleP
Montreal
International H
Hello you alls, I am about to bid on an Iseki on ebay, I would like to how much a ISEKI TU180F 4X4 with front end loader might weight. More or less than 3000 lbs.?
   / Is my truck big enough? #2
I'd say you're in a very close ballpark at 3,000 #. I'd error to slightly more if the tires are filled.
Thank you Square1
   / Is my truck big enough? #4
Tractordata lists a TU180 as an 18 HP tractor weighing 2116 lb. without loader. Loader may be another 650-750 lb. so should be under 3k total. You didn't mention what size truck are you planning to use to tow it so can't answer if its big enough.
TractorData.com Iseki TU180 tractor information
Thank you George, I am drive a GMC Sonoma 4.3 liter. If I remember the pulling is about 5800 #. The problem is the trailer, probably around 2000 # To close for a long ride.
Any way I missed the bid, I save my truck.
Never mind.
LMC G500-500A LOT NUMBER 232 (A53084)
LMC G500-500A LOT...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2022 JOHN DEERE 6140M LOT NUMBER 264 (A53084)
2022 JOHN DEERE...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
