Hello you alls, I am about to bid on an Iseki on ebay, I would like to how much a ISEKI TU180F 4X4 with front end loader might weight. More or less than 3000 lbs.?
Tractordata lists a TU180 as an 18 HP tractor weighing 2116 lb. without loader. Loader may be another 650-750 lb. so should be under 3k total. You didn't mention what size truck are you planning to use to tow it so can't answer if its big enough.
Thank you George, I am drive a GMC Sonoma 4.3 liter. If I remember the pulling is about 5800 #. The problem is the trailer, probably around 2000 # To close for a long ride.
Any way I missed the bid, I save my truck.
