Is My Optical Mouse Dying?
/ Is My Optical Mouse Dying? #1
Bird
Rest in Peace
Corinth, Texas
Another question from the computer dummy. I bought a new Hewlett-Packard desktop computer in January, 2008, along with a 19" monitor. The mouse that came with it was defective to start with, and Best Buy said they didn't have another one just like it, so they gave me a Gateway, Model MOAKUO, optical mouse that they said was more expensive. It's worked great until the last couple of days. But several times the last couple of days, it just quits working. The cursor stays in one place and will not move. I go to the back of the computer tower, unplug the USB cable, plug it back in, and the mouse works again usually! Last night I unplugged and plugged it back in a couple of times with no luck, but it was bedtime, so I decided I'd wait until morning to mess with it. Of course, the computer was left on all night, as usual. When I got up this morning, the mouse was working fine.:confused: So, it's quit on me twice so far today, I unplug it and plug it back in and everything's good again.
Does this mean my mouse is dying, or could it be something else?
/ Is My Optical Mouse Dying? #2
Is it a wireless mouse if so change the battery.
/ Is My Optical Mouse Dying? #4
You might check the device manager to make sure there are no problems with the USB port/driver...also, imediately after the failure check the system logs for an error message...but mice do wear out...
Device manager shows all USB ports working normally. I'm not sure how I'd get to the system logs if the mouse won't move the cursor, and if there were an error message there, I probably wouldn't know what it meant.:eek:
/ Is My Optical Mouse Dying? #6
best bet is the mouse is wearing out...
to see the system logs...from the control panel select 'Administrative Tools' then look for "Event Viewer"...there should be a series of system logs...all may not be activated...check the "system" and the "application" logs...they will be listed in the system timeline.
Sometimes if there is a problem the logs can give you a clue where to look...especially if it is an external port that is messing up...and other times you can run a search for the error code and solve some mysteries....
also...the current settings (if you're not logged in as an Administrator) it may not let you see the "Administrator Tools" icon...
I can look at the Administrator Tools and see the system and application logs but then I don't understand what I'm looking at, or what I'm looking for. I found some error code 1000 and 1002, etc. If the problem really is the mouse, I can go buy one, but I reckon I just need to get a son-in-law to come take a look at it and fix it for me.
/ Is My Optical Mouse Dying? #8
Have you tried the mouse in a different USB port? It can be the connector, the wire, internal mouse fault, or ??? Swap the mouse to a different port and if the problem continues go get a Logitech mouse.:D
/ Is My Optical Mouse Dying? #9
Replace your mouse.....if that doesn't take care of it, you have a bad USB port on your computer. I just went through the same thing. After 7 years of use, my faithful mouse bit the dust.
It is most likely a loose wire where the wire comes out of the mouse. Mine was worn through where the case presses against the cable.
/ Is My Optical Mouse Dying? #10
...I don't understand what I'm looking at, or what I'm looking for...
if it was a USB port intermittently malfunctioning...there would be some red flags in the system log...sometimes when the port is physically bad the device manager will report that it is OK
the system logs are good troubleshooting tools but you must be able to fix the timeline to the occurrence of the problem...many of the entries will be nominal run errors that are nothing to be concerned about if the system is else-wise working OK...
/ Is My Optical Mouse Dying? #12
I'm with Jinman.
Try different USB port.
If this doesn't work, suspect defective wire....tape wire where it attaches to USB plug and seek to make immobile. Do same where wire comes out of optical mouse.
Since it "fixed" itself overnight...might suspect mouse driver... might reload or look for new one of above do not help.
Last resort, try another mouse.......borrowed or purchased....
Hope you solve it... vexing are these computer problems:confused2:
/ Is My Optical Mouse Dying? #13
Check the hole under the mouse for dirt interfering with the optical light. Even a miniscule amount will cause the mouse to malfunction.
/ Is My Optical Mouse Dying? #14
Like already stated. Get a new mouse. I have changed to a MS wireless mouse. Long battery life and ease of use. I have 3 5000 series mice. One on each computer. Staples has them on sale this Sunday for $30.
That presents another question.:laughing: I see there are widely varying prices on mice, but what makes a $30 one better than a $15 one? I know both of my brothers use Logitech wireless and claim to never have any trouble with them, except one of them says he has to replace the batteries in his about every 6 months. Of course I've never had any trouble with a mouse either until this one.:laughing:
/ Is My Optical Mouse Dying? #17
Mice come in many shapes, really....you need to make sure what you get fits your hand well.
The variety is huge
trackball...
optical
various numbers of buttons placed at different locations, scroll wheels
programmable buttons...can be extremely useful if you use the programming
touchpads
wireless/wired
it's all about features.... after you solve the most important thing...does it properly fit your hand,.
/ Is My Optical Mouse Dying? #18
No one mentioned this, so I will...
Try the mouse on a different surface. Optical mice work by reflecting light off the surface below them and then back up to a receiver on the mouse.
You haven't changed mouse pads, have you?
Just thinking. :)
/ Is My Optical Mouse Dying? #19
A lot of times...it is the glide surface points on the bottom of the mouse that wear unevenly and it causes problems with the reflection of the light engine...
laser mice seem to be more sensitive to this than LED mice
Just thinking. :)
I haven't even used a mouse pad since I got this optical mouse. It's just on a light colored oak veneer surface.
And in spite of the problems I had with it for a couple of days, it's worked just fine ever since I started this thread.:confused::eek::laughing:
2013 PETERBILT 367 FLATTOP SLEEPER TRUCK (A67714)
2013 PETERBILT 367...
2002 Bombardier Evinrude 90HP Outboard Boat Motor. (A66738)
2002 Bombardier...
LAWN MOWERS/WEEDEATER/HEDGER (A67714)
LAWN...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
SARLO (A64557)
SARLO (A64557)
