Is my loader valve shot & which replacement
   / Is my loader valve shot & which replacement #1
amashinga
Bronze Member
Hey folks,
Endless hassles with my old dukes loader valve, It seems to be bleeding all over the place, and missing some seals. I think it is time for a replacement, agreed ?.
I dont understand the small differences between these valves, any suggestions, or experience on what would be good for a small loader application ?. 2 by prince, 2 by brand.
Prince 1
Prince 2
Brand 1
Brand 2
(If its not obvious, I am learning as I go here) :)
   / Is my loader valve shot & which replacement #2
Either of the BRAND joystick valves will work good for you. I would not want one of the two-handled PRINCE valves to operate a FEL.
Another option is THIS valve from the SurplusCenter.
   / Is my loader valve shot & which replacement #3
This is probably a dumb question but when they say a port size of #8SAE what does that mean in the world of fitting sizes: in other words are they 3/4" fittings, 1/2"? What do you need to get to hook them up?
   / Is my loader valve shot & which replacement #4
One of these CHARTS should help you...
#8 SAE in this case means it's a 1/2" fitting (each # is 1/16th of a inch so...8/16ths = 1/2")
The SAE refers to the type of fitting, it's a straight thread with an O-Ring Boss (called ORB)
Clear as mud?:D
   / Is my loader valve shot & which replacement #5
That's why I love this site!!! Thanks for the info.
   / Is my loader valve shot & which replacement #6
Amashinga,
The valves you have listed as Brand 1 and Brand 2 are the same valve. The model number "PLV22RFSTKAB" tells everything about the valve. Brand hydraulics web site BRAND HYDRAULICS - Product Catalog explains what all the letters mean. Kenny that valve at the surplus web site is also the same one as Brand 1 and Brand 2. Surplus is more expensive than Northern however.
I installed the brand valve on my tractor about three months ago and am happy with it. You will have to order the power beyond cartridge seperately. I did have to get that from Surplus as Northern didn't list it.
Let me know if I can help.
Ken
   / Is my loader valve shot & which replacement #7
One of the Brand valves has regeneration and the other doesn't. What is regeneration and what does it do?
   / Is my loader valve shot & which replacement #8
Read THIS post for a detailed explanation, also a search of the term "regen" will turn up hours of reading on the subject.
1996 International Water Truck with a Caterpillar Engine (A53472)
1996 International...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
