Is my loader valve shot & which replacement
/ Is my loader valve shot & which replacement #1
amashinga
Hey folks,
Endless hassles with my old dukes loader valve, It seems to be bleeding all over the place, and missing some seals. I think it is time for a replacement, agreed ?.
I dont understand the small differences between these valves, any suggestions, or experience on what would be good for a small loader application ?. 2 by prince, 2 by brand.
Prince 1
Prince 2
Brand 1
Brand 2
(If its not obvious, I am learning as I go here) :)
/ Is my loader valve shot & which replacement #2
Either of the BRAND joystick valves will work good for you. I would not want one of the two-handled PRINCE valves to operate a FEL.
Another option is THIS valve from the SurplusCenter.
/ Is my loader valve shot & which replacement #3
This is probably a dumb question but when they say a port size of #8SAE what does that mean in the world of fitting sizes: in other words are they 3/4" fittings, 1/2"? What do you need to get to hook them up?
/ Is my loader valve shot & which replacement #4
One of these CHARTS should help you...
#8 SAE in this case means it's a 1/2" fitting (each # is 1/16th of a inch so...8/16ths = 1/2")
The SAE refers to the type of fitting, it's a straight thread with an O-Ring Boss (called ORB)
Clear as mud?:D
/ Is my loader valve shot & which replacement #5
That's why I love this site!!! Thanks for the info.
/ Is my loader valve shot & which replacement #6
Amashinga,
The valves you have listed as Brand 1 and Brand 2 are the same valve. The model number "PLV22RFSTKAB" tells everything about the valve. Brand hydraulics web site BRAND HYDRAULICS - Product Catalog explains what all the letters mean. Kenny that valve at the surplus web site is also the same one as Brand 1 and Brand 2. Surplus is more expensive than Northern however.
I installed the brand valve on my tractor about three months ago and am happy with it. You will have to order the power beyond cartridge seperately. I did have to get that from Surplus as Northern didn't list it.
Let me know if I can help.
Ken
/ Is my loader valve shot & which replacement #7
One of the Brand valves has regeneration and the other doesn't. What is regeneration and what does it do?
/ Is my loader valve shot & which replacement #8
Read THIS post for a detailed explanation, also a search of the term "regen" will turn up hours of reading on the subject.
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2016 Jeep Patriot SUV (A61569)
2016 Jeep Patriot...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2023 Globe Trailer...
