Is JD Quick Hitch Cat 1&2 Or Just Cat 1?
   / Is JD Quick Hitch Cat 1&2 Or Just Cat 1? #1
wirlybird
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
I have a pretty new JD quick hitch I got in a deal with a tractor.
I am going to sell it but am wondering if it is just Cat 1 or is it Cat 1&2? No label with a part number on it.
I have the bushings needed for Cat 1 implement but will it also work with Cat 2? The pins to mount it to the tractor are Cat 1.
Thanks for any insight.
   / Is JD Quick Hitch Cat 1&2 Or Just Cat 1? #2
That would be Cat I only I believe.
Personally I have never seen one. My experience is with Cat 2 and 3 only
   / Is JD Quick Hitch Cat 1&2 Or Just Cat 1? #3
I have never seen a dual fit quick hitch;
the lower link spacing from Cat 1 to Cat 2 is six inches (28" and 34") and 2 to 3 is another 6 inches (34" to 40".
You would almost have to have two sets of latches for a dual sized hitch.
And then the height of the top link hook is different also.
Ahh, ok. I didn't think of the width.
I just wondered since it requires the Cat 1 pins, on the implement, to have large bushings on them.
Maybe they use the hooks on different models?
   / Is JD Quick Hitch Cat 1&2 Or Just Cat 1? #5
The hooks on the QA will correspond to the categories' top and lower link pin diameters.
   / Is JD Quick Hitch Cat 1&2 Or Just Cat 1? #6
Specification for QH's...
That is the part I don't get and why I wondered. The Cat1 quick hitch says it requires bushing for the lower pins. Not need for the upper if it is a quick hitch compatible implement since the large "pin" is already there.
Ok, looking at the chart it seems that Cat 1, 2 & 3 use the same lower and upper hook socket dimensions. That explains it.
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
