Is it time for a gasoline engine tractor?
   / Is it time for a gasoline engine tractor? #261
Not true at all. Many cars had trouble running it in the 80s is why it went away then came back in this decade.
It didn't go away everywhere. We always had it in South Dakota.
Ethanol has done nothing but drive up the cost of corn, meat, and give the farmers some extra $$$ for corn crops. It produces less energy and gets poorer fuel mileage than non ethanol fuel. The extra fuel consumed means we still use the same amount of fossil fuel we always have. We just don't go as far on a tank.
E10 uses the ethanol instead of things like MTFE. It is used to put more O2 in the gas (read hydrocarbon reduction) along with more octane. E10 is not meant to try and replace our need for gasoline, it is only for emissions. The mixes greater than 10% are there to try and burn something besides gas.
   / Is it time for a gasoline engine tractor? #262
I follow your logic, but I just want to use a real life example to make sure I'm on the same page. When I was in college, my dad replaced me with a bigger tractor. The Case 930 would pull a bigger plow than the 730. :) So I was using it to plow some alfalfa ground. In the low ground, it would lug down about 500 rpm, but keep fighting through it and recover the rpm after about 200 yards. I never had to downshift, but the black smoke was rolling out. So at what point was I at 90% and 100% ?
Dang, I miss that beast. According to Tractordata, it was 80 pto hp, but pulling that 5/16's it kept up with the neighbor's Deutz that I think was the DX110 at 102 hp.
Did you add throttle? Did rpms come up?
   / Is it time for a gasoline engine tractor? #263
Our JD also had showed more on the Dyno then rated. It should for the fuel that it uses!
As for generators. That's why it important to start with something that runs at 1800 rpm. It's just purring along putting out only about half of what the engine is capable of. When my little JD 770 (Yanmar) ran my Onan 15 kw PTO genset, you pulled that throttle wide open to get 540/60 cycles. As the song says, "that's all there is and there ain't no more"!
As I mentioned several times before, I tried an experiment with a 2-1 PTO gearbox, thinking I could use this for light loads. The tractor would not even turn it with no load! It just surged in a most disturbing way, trying to catch it's breath. That genset did have a speed-up sprocket driven arrangement, that did not help. The Rotor spun quite quickly.
Too many are equating rpm with hp.. They are different..
   / Is it time for a gasoline engine tractor? #264
All I can say is, that must have been one sick Deutz!!
SR
   / Is it time for a gasoline engine tractor? #266
   / Is it time for a gasoline engine tractor? #268
It didn't go away everywhere. We always had it in South Dakota. E10 uses the ethanol instead of things like MTFE. It is used to put more O2 in the gas (read hydrocarbon reduction) along with more octane. E10 is not meant to try and replace our need for gasoline, it is only for emissions. The mixes greater than 10% are there to try and burn something besides gas.
It was MTBE, which is Methyl Tert-Butyl Ether which also contains extra oxygen. The big problem with MTBE is it very soluble in water, when there is a leak in a tank MTBE basically flew through the groundwater contaminating it. Hence why we now use Ethanol.
   / Is it time for a gasoline engine tractor? #269
If you guys want a gas powered tractor I've got two D-17 Allis Chalmers sitting in the shed you can run...
All you need is a little cash to keep those tanks full of fuel...
One series 3 and one series 4...
The series 4 has over 4500 hours and the engine has not been touched...
The series 3 I think had the heads redone at 4000 plus hours...
Good old tractors with well built engines...
Speaking of power those Power Crater engines develop 63 engine and 53 PTO HP at 1650 RPM...
4 Cylinder 226 cubic inch gasses...
Burns around 4.5 gal per hour per Nebraska tests...
   / Is it time for a gasoline engine tractor? #270
You are correct, thank you for catching my typo.
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
