Is it time for a gasoline engine tractor?
   / Is it time for a gasoline engine tractor? #61
It's never time for a gas tractor with ethanol in the fuels. Never...HS
   / Is it time for a gasoline engine tractor? #62
1966 - Them's was the day's! Four barrels and 10.5 compression in front of a 747. Change the cam, advance the ignition a touch, put in colder plugs, dual points and let the hair blow in the wind. Still had hair back then!
That's how I lost mine! (anyone else notice all the emojis are bald?) :laughing:
   / Is it time for a gasoline engine tractor? #64
Because pretty much EVERY CAR MANUFACTURED SINCE THE 80's HAS RUN ON 10% ETHANOL WITHOUT ISSUES....
agreed, but it's been deadly to our small engines.
   / Is it time for a gasoline engine tractor? #65
I've been using it for 30+ years and the only problem I can attribute to it on my personal equipment is the fuel line in one chainsaw.
And since this thread is about gasoline tractors, I, too had a gasoline tractor for about 10 years. It was a late 70's IH 2500b tractor loader, 4 cylinder gas engine, HST transmission, full cab, rated at 50HP on the PTO.
TractorData.com International Harvester 25B industrial tractor information
It was the industrial version of the IH 574.
TractorData.com International Harvester 574 tractor information
It was a fine, powerful machine, but it drank lots of fuel. Never had any fuel problems with it that I could attest to 10% ethanol.
My current machine is also gasoline, but its only a Kohler 25HP gas engine, like a lawn tractor engine, not like a tractor engine. It burns a little over a gallon per hour. No fuel problems in 15 years.
   / Is it time for a gasoline engine tractor? #66
Now Moss, don't be throwing out facts in a good scare tactic hissy fit thread! ;)
   / Is it time for a gasoline engine tractor? #67
You and your working gassers are an enigma. :)
   / Is it time for a gasoline engine tractor? #69
My Dixie chopper can't hang with my diesel mower in fuel consumption or power. The rated HP is identical and the actual power output isn't much different, but the diesel smokes it in fuel economy. The gas burns about 1.5 gallons per hour and the diesel burns about 1/2 gallon per hour. Diesel is about 2.20 here and ethanol free gas is about 2.60.
   / Is it time for a gasoline engine tractor? #70
The ethanol fuel causes huge problems with most low use engines due to phase separation. The water rusts out fuel tanks, corrodes carbs and fuel pumps, sometimes so badly they are not rebuildable.
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
BUSH HOG 8 SHREDDER (A58214)
BUSH HOG 8...
