Is it possible to swail with a 400??
   / Is it possible to swail with a 400?? #31
Re: larger, taller tires on a 400???
Robert:
Keep in mind that I am not an engineer, and don't have data on the 422 that would allow analysis, even if I were an engineer. Power Trac advises against dual wheels on the 400 series, because of loads on the wheel motor mounts when the outer tire is on a high spot, and the machine is loaded. Taller tires shouldn't present that problem. They would raise the CG somewhat, and increase loads in fast turns, but I would think the latter are a minor consideration. I would certainly recommend taller wheels and tires before moving the wheel motors.
Power Trac has lower tires on their dual setups on the larger tractors than the single tires on the same machines.
If you increase tire size, you do reduce pulling force and increase speed, proportionally to the change in radius.
There are quite a number of wheel/tire combinations out there. If you find the right bolt pattern, it sounds worth a try.
Another alternative, of course, is to get a 4 n 1 bucket or box blade, and smooth the area you run over so the increased clearance isn't needed. /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
   / Is it possible to swail with a 400?? #32
Just out of curiosity, watcha need the additional ground clearance for? /w3tcompact/icons/smile.gif
   / Is it possible to swail with a 400?? #33
MR,
I have a situation that has what can best be described as a tank trap. A row of 12"+/- of concrete piers. 3 rows spaced about 24-28" apart. I have to "leave them as I found them" each time I cross them. I go across about 4 times in the average week. This situation works with an ATV, but not much else. If you have any ideas, please let me know.
Robert
X X X X X X X X
X X X X X X X X X
X X X X X X X X X X X X
THIS ABOUT WHAT IT LOOKS LIKE.
   / Is it possible to swail with a 400?? #34
Oh, well..... uh.... that's some tough terrain. What the heck was that set up for?
   / Is it possible to swail with a 400?? #35
How about using a couple of loads of fill to raise the ground level around the obstacles?
Bryce,
A long time ago...there was a industrial surplus place near to where I lived with dc gearmotors and other multi-purpose
use stuff--don't know if it still exists... they were $35-50...
Ebay is probably the most well known source today...I'm sure there are other places I haven't even looked for yet...
Is this for an adjustable top link setup?(just curious)
   / Is it possible to swail with a 400?? #37
It is actually to lift the implement. I have an ATV with a 3 pt. hitch. It actually works pretty good, but I am using a winch to lift right now. Robert
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
207279 (A52708)
207279 (A52708)
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
