Is it okay to add dirt to the top of a septic drainfield?
   / Is it okay to add dirt to the top of a septic drainfield? #1
Pushing_Tin
Eugene, Oregon
JD 3320
I am wondering if it is okay to add dirt on the top of a septic drainfield. There are low areas in the field that can pond water during the rainy season and I'd like to fill these areas in. I know to keep heavy equipment off of the lines, but is there any other reason not to do that? :confused:
   / Is it okay to add dirt to the top of a septic drainfield? #2
That would depend on the drain field, the drain tile, the soil, the depth, and prolly several other things.
Standing water on a drain field intuitively sounds like a bad thing. Draining the water away from the field seems like a good idea.
   / Is it okay to add dirt to the top of a septic drainfield? #3
My only thought is that it would interfere with the suns heat from evaporating some of the moisture? Water standing sounds like a normal if you have received a lot of rain. After all water comes out of your tank and its coming out of the sky.
   / Is it okay to add dirt to the top of a septic drainfield? #4
I wouldnt see a problem filling in those low spots....the waste disperses downwards once it leaves the system...you dont want it coming to the surface....The concern I would have is what equipment you are going to use.....Is it to heavy and would damage the tank or runners.
I would use my 2320 once it dries out enough.
   / Is it okay to add dirt to the top of a septic drainfield? #6
Do you know how the drainfield is constructed?
Mine is 3' down in sand. I have no restrictions on driving over it. In fact, have my firewood stacked between the three runs (see pic). This drain field is 200' from the septic tank.
Some around here have to have what is called a "mound" system (their land won't perk), and the drainfield is constructed above ground in a mound. Their recommendations is no equipment on them.
   / Is it okay to add dirt to the top of a septic drainfield? #7
It's called a pressure system up our way, it is what I have. Pumps up into the field. Special sand about 3ft above the rest of the ground. Had to put it in due to regulations, clay ground plus close to the creek. Cost lots of $. :mad:
I do use my ride on lawn tractor to mow it but nothing heavier as it would probably cush the field. Was told not to drive on it with anything heavy or to let trees grow on it.
   / Is it okay to add dirt to the top of a septic drainfield? #8
My belief is that the septic drain field must be aerobic, i.e., enough oxygen from the air for oxygen breathing bacteria to work on the waste.
The tank itself is anerobic, and contains a different type of bacteria.
If you add very much dirt you will suffocate the aerobic bacteria in the soil at the level of the discharge pipes and may screw things up.
   / Is it okay to add dirt to the top of a septic drainfield? #9
Drain fields are usually ok to drive over with avergae equipment such as vehicles, tractors, etc. I'd be nervous having something as heavy as a concrete truck drive over them. Now your tank is a different story. I wouldn't put anything other than a riding mower or compact tractor over it.
   / Is it okay to add dirt to the top of a septic drainfield? #10
I suspect your field looks similar to mine - some small sags over the lines where the dirt has settled in. If so, you shouldn't need more than 6-12" of dirt, right? That should be fine, and your 2320 with a scoop of dirt shouldn't hurt anything. I run my 2305 over my drain field with a full bucket of dirt and the weight box on the back end - no worries...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
CFG Industrial SAII100 (A50123)
CFG Industrial...
