Is It My Hydraulics?
   / Is It My Hydraulics? #1
slashk
Oklahoma City
kubota
Hello Everyone - Looking for some help. My tractor will start up just fine and will go forward and backward for a few minutes then just quit. Not the engine but the forward and backward motion. Also, I can turn the tractor off for a few minutes and then start it again and it will run forward and backwards for a few then just quit again. Very frustrated!!!! Any body have any idea what is causing this?
   / Is It My Hydraulics? #2
It would help if you stated what model tractor you have.
   / Is It My Hydraulics? #3
What model? What transmission? Have you checked the oil levels? When was the last time it had a filter and oil change? Not much to go on here.
Kim
Kubota B7100 - believe it is HST - All oil levels fine - Just Changed Oil and Hydraulic Filters and fluids.
   / Is It My Hydraulics? #6
Was the suction screen cleaned when the oil and filter were changed? I'm not familiar with that model but would assume there is one. How many hours on the tractor?
Kim
Will have to go and check the hours. Have nooooo idea what a suction screen is or where it is.
   / Is It My Hydraulics? #8
Check and clean or replace. Item 4 on the PDF from MEssinicks.
It may be behind a large cap on the foot pedal.
A lot of tractors have a suction screen as the first filter.
  • B-7100 hyd.pdf
Thank you very much! Will try that when I get off work tonight and see if it solves the issue. Will post to let you know!
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52705)
2014 CATERPILLAR...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
Miles read : 112,969 (A50323)
Miles read ...
