Is it a Massey Ferguson 1120 0r 1205?
   / Is it a Massey Ferguson 1120 0r 1205? #1
DennisFreytag
Just bought a compact 4 wheel drive tractor and don't know what manual I need. The hood says 1120 and by the transmission there is a sticker that says: Iseki Model MF 1205 MSN 9444 SER# E 03405 Weight 620 KG I need injection pump work on it.The pump body has these numbers K-98 D.849L or it could be O.849L its hard to read. Does anyone have a manual they could scan and e-mail? What engine is this and what manuals do I need? Thanks, Dennis
   / Is it a Massey Ferguson 1120 0r 1205? #2
You may try Rainbow in Hawaii The are a full line Iseki dealer and would know MF cross-overs. For example, here is the list for Bolens Bolen-Iseki
   / Is it a Massey Ferguson 1120 0r 1205? #3
Dennis,
I don't know anything about a 1120, but if it is a MF 1205, I can tell you if you will post a picture. The MF 1205 is also the same as a Iseki TM215. On the engine, in front of the oil filter it should say E393. That is one in the MF 1205. If this is the right engine, I have the specifications for its pump for a rebuild. BTW, what is the reason, that you need pump work? What is it doing?
When I bought this tractor it was thought to be in need of a new injection pump. It started and blew out lots of black smoke. Fuel should be white, right? It was supposed to have new rings in it. I think any mechanical work done before I bought it could be suspect. After I got it home, I could not get it to start. I disconnected the injector lines at the pump and it puts out a small amount of fuel on the center line, no pressure and thats it. I tried spraying WD40 in the intake and it would not fire on that, also tried a little ether, it almost fires on both but will not run. Got any ideas? Thanks, Dennis
2025 JMR Tree Boom Skid Steer Attachment (A50322)
2025 JMR Tree Boom...
2015 Ford F-550 XL (A50120)
2015 Ford F-550 XL...
2011 Kubota KX080-3 Midi Excavator (A50322)
2011 Kubota...
2014 John Deere 6105D (A50120)
2014 John Deere...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
