Is it a Massey Ferguson 1120 0r 1205?
   / Is it a Massey Ferguson 1120 0r 1205? #1
DennisFreytag
Just bought a compact 4 wheel drive tractor and don't know what manual I need. The hood says 1120 and by the transmission there is a sticker that says: Iseki Model MF 1205 MSN 9444 SER# E 03405 Weight 620 KG I need injection pump work on it.The pump body has these numbers K-98 D.849L or it could be O.849L its hard to read. Does anyone have a manual they could scan and e-mail? What engine is this and what manuals do I need? Thanks, Dennis
   / Is it a Massey Ferguson 1120 0r 1205? #2
You may try Rainbow in Hawaii The are a full line Iseki dealer and would know MF cross-overs. For example, here is the list for Bolens Bolen-Iseki
   / Is it a Massey Ferguson 1120 0r 1205? #3
Dennis,
I don't know anything about a 1120, but if it is a MF 1205, I can tell you if you will post a picture. The MF 1205 is also the same as a Iseki TM215. On the engine, in front of the oil filter it should say E393. That is one in the MF 1205. If this is the right engine, I have the specifications for its pump for a rebuild. BTW, what is the reason, that you need pump work? What is it doing?
When I bought this tractor it was thought to be in need of a new injection pump. It started and blew out lots of black smoke. Fuel should be white, right? It was supposed to have new rings in it. I think any mechanical work done before I bought it could be suspect. After I got it home, I could not get it to start. I disconnected the injector lines at the pump and it puts out a small amount of fuel on the center line, no pressure and thats it. I tried spraying WD40 in the intake and it would not fire on that, also tried a little ether, it almost fires on both but will not run. Got any ideas? Thanks, Dennis
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
1991 Great Dane 48' Reefer Trailer (TITLE) (A50774)
1991 Great Dane...
43006 (A51691)
43006 (A51691)
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
