Is Creep Gear Option Available on 5090E / 5100E OS ??
   / Is Creep Gear Option Available on 5090E / 5100E OS ?? #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Just like title says ??
I know the 24F/12R is an option but it still doesn’t slow the tractor down in A range 1st gear like the creep option.
Even the 16spd in a M series still isn’t any slower in A1 than a 12spd E in A1 gear.
   / Is Creep Gear Option Available on 5090E / 5100E OS ?? #2
There is no creeper option on E series. The M series offers creeper with speeds as low as .16 mph at 2200 engine rpm.
   / Is Creep Gear Option Available on 5090E / 5100E OS ?? #3
My Kubota M6040 is rated at 1.4 mph @ 2600 rpm - 1st gear, L range. I just reduce engine rpm's if I need to go slower. However - you are right, nothing is quite as slow at a set of creeper gears.
I was thinking Creep was ONLY available in a M series 32spd :thumbsup:
My Kubota M6040 is rated at 1.4 mph @ 2600 rpm - 1st gear, L range ...
All 3 of my E’s are .4 mph at idle in A1 & .7 at 1500rpm.
Which is too fast running a caking machine in a chicken house.
I think certain vegetable farmer seeding applications out West require speeds under .4 mph :confused:
I lowered my tractors height AND gearing by swapping from Tall R1 Ag tires TO 12”+ shorter R4 Industrial Tires but a Slower creep gear is still needed at times.
   / Is Creep Gear Option Available on 5090E / 5100E OS ?? #7
A creeper is available in the 5E 3 cyl units (5045E, 5055E, 5065E, 5075E) with the 9-speed top shaft synchronized transmission. The speed in the lowest creep gear in the creeper is 0.25 mph (400 meters/hour) at full rated engine speed with 16.9-28 tires according to Deere's literature and a calculator. Smaller tires such as the 16.9-24 R4 tires offered on this tractor line would slow this down about another 10%.
The creeper is NOT available on any 5E tractor with a PowerReverser transmission. The PowerReverser is the only transmission option on the 5E 4 cylinder units such as the 5090E and 5100E so no creeper is available. A creeper is available on 5M series MFWD tractors with the 32/16 PowerReverser including open station models.
Ok that makes sense.
A salesman told my buddy it was an option on a E series.
So that makes sense why.
Thanks for clarifying that info :thumbsup:
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
Tortoise Statue (A55853)
Tortoise Statue...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2023 Kubota Z252KH-54 Zero Turn Mower (A55314)
2023 Kubota...
2020 Deere 325G (A50123)
2020 Deere 325G...
