Is anyone using a Mulching Kit on a BX MMM?
/ Is anyone using a Mulching Kit on a BX MMM? #1
mshumack
Bronze Member
Central FL, Florida
2015 Kubota BX2370 w/ FEL and MMM
I ordered a Mulching Kit for a 60" Fine-Cut deck. I should have asked here first - but is anyone using one, and if so, how do you like it?
Also, the Kubota Options sheet I have lists just one Mulching Kit for a BX2370/BX25, a "ZG3059" but the notes say this kit only fits the RCK54-P23BX mower and I have a RCK60-26BX 60" deck. I hope the Dealer did not order me a mulching kit for a 54" deck. I'll call on Monday to double check.
Maybe there is another part number for the 60" deck (just not listed on the Options sheet I have).
/ Is anyone using a Mulching Kit on a BX MMM? #2
I've had a kit on mine, a 60" regular deck since mine was almost new. A cant tell you if its the same for all the decks or not. I like mine. As I recall, the directions say to leave the deflector chute on but I removed mine. It narrows things up and distributes the grass a lot more evenly. The kit is pretty complete and has a lot of parts.
/ Is anyone using a Mulching Kit on a BX MMM? #3
I had one on my 54P. If it works as poorly as the one I had, save your money!
The kit costs $168, so if it doesn't work well I can always switch back to standard cut. At least it won't be an expensive lesson.
/ Is anyone using a Mulching Kit on a BX MMM? #5
Cheaper than here for sure.
IIRC, after the blades, the kit was 3 hundred something here.
/ Is anyone using a Mulching Kit on a BX MMM? #7
I have a mulching kit on my Dixie chopper. It sucks, and makes rows of unmulched grass. It works some better in leafs, but then the air flow comes out the front of the deck and blows dust up in your face. Pretty much it's only use is to reduce the chance of throwing rocks.
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
19008 (A56859)
19008 (A56859)
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61306)
Bulk Lot of NEW...
1981 Kari Kool CTK 6,500 Gallon T/A Tanker Trailer (A59230)
1981 Kari Kool CTK...
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
