Is any one using a DR.vacuum with their JD?
   / Is any one using a DR.vacuum with their JD? #1
ragkar
Platinum Member
eastern PA-lower Poconos
JD2320 w/R4 $21,100 w/7.16%off
I noticed that the biggest JD material collection system has a capacity of 14 bushels, whereas the DR.vacuum has a 315 gallon storage capacity.
Don't you love how they use strange units to give you difficulties in evaluating and comparing them?
Okay, the JD model is 15 cubic feet and the DR model is 42 cubic feet.
   / Is any one using a DR.vacuum with their JD? #2
you can ask google "14 bushels to gallons" ..... format is number units "to" units
14 US bushels = 130.328491 US gallons
or 14 US bushels = 17.4223852 cubic feet
or 315 US gallons = 42.1093752 cubic feet
or 315 US gallons = 33.8375743 US bushels
   / Is any one using a DR.vacuum with their JD? #3
I had looked into them but decided against the DR since it's a trailer type of setup and I figured it would limit my mobility too much. Rather than the 3-bag MCS, you may be able to convince your dealer to get you the larger hydraulic dump system and some front counterweights. Had I known that was possible I probably would have chosen that route just for the 3PH mounting:
http://www.tractorbynet.com/forums/jd-owning-operating/100104-jd-mcs-options.html
   / Is any one using a DR.vacuum with their JD? #4
If you think the regular MCS is expensive you'll fall over when you get the price on the hydraulic dump. Yikes!
Scott
PENDING SELLER CONFIRMATIONS (A56129)
PENDING SELLER...
SKLP Windmill Shooting Target (A53316)
SKLP Windmill...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A55787)
2022 Caterpillar...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2000 KENWORTH W900L MID-ROOF SLEEPER TRI-AXLE TRUCK (A55745)
2000 KENWORTH...
