Buying Advice Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #1
dfisher654
Tecumseh
Ford 4000
I have a Ford 4000 and I am looking at buying a 6 foot Land Pride Shredder RCR2672. Will my tractor be able to lift it? According to the spec it weights 1,046 pounds. Anyone have this combination. thanks for your responses.
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #2
Sorry, I don't have that exact combination.
The tractor will lift it. If there's an issue it might be concerning keeping the front tires on the ground. May need some front end ballast. My 3910 will handle some very heavy 3pt loads and does pretty well at keeping it's front tires on the ground. But it's FWD. I use a 6' Rhino brush cutter with no lightness on the front.
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #3
I scrounged and found a couple pics. Again, the 3pt has great capability, if you can keep the front end of the tractor on the ground. When using my tree puller I either pull the tree or lift the front tires by simply using the 3pt.
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #4
I have a 3910 2wd and I have no problem lifting and carrying the same size haybale ovrszd showed. I have used my 6' Landpride 1X72 series bushhog on some serious hills no problem as well as a 7' Howse heavy mower. With the 7' on some steep hills the front end would get a little light but could have easily been solved with a few front end weights.
One summer I also ran a Ford 3400 with a 6' HD Bushhog brand cutter mowing steep roadbanks for the county. Never had an issue and that was the heaviest 6' mower I've seen.
I think your 4000 will be fine.
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #5
Good stuff right there. Exactly what he needed to hear. :)
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #6
I run a Brown 472 that is similar to your shredder. I think that it specs at 1060# with 120 HP gear box. My 4610 SU pulls it fine but I did get a little light on the front end. I added front weights and bracket to the tractor. Now I have no issues. Your 4000 will not have any issues lifting or running the unit at all. That is a very nice shredder.
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #7
Then again, we don't know the age of his 4000?? If it's the early model it's really going to be light in the front.
The tractor is a 1973 Diesel with a loader on it. I appreciate all of the replies.
   / Is a Land Pride 6' RCR2672 Shredder To Heavy for a Ford 4000 Tractor #9
That clarifies that!!!! If you leave the loader on you can carry twice that size of cutter. :)
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
2023 Evolution Classic 4 Pro 48V Golf Cart (A53002)
2023 Evolution...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
(6) Goodyear 8.25 R20 Tires (A51573)
(6) Goodyear 8.25...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
