Is a JD 400 a good parts machine for a JD 420???
   / Is a JD 400 a good parts machine for a JD 420??? #1
formflier
Moorhead, MN
john deere 420
i've got a chance to pick up a John Deere 400 garden tractor that has a blown engine.
I've got a JD 420 that I'm trying to keep running. I'm wondering how many of the parts are interchangeable??
Basically would it be a good parts machine.
thanks
   / Is a JD 400 a good parts machine for a JD 420??? #2
I'm not absolutely sure,but being the 400 was the predecessor to the 420,I would think there would be alot of the same parts on both machines.
Greg
   / Is a JD 400 a good parts machine for a JD 420??? #3
Probably the best place to check is JD Parts. Look at both models and compare like parts, ie: hydraulic valve bodies, mower lifts, etc. I was always under the impression that the 400 was more or less a stand alone model, only attachments made for it would fit.
Todd
   / Is a JD 400 a good parts machine for a JD 420??? #4
I'd do some pretty careful checking!
400 used a Kohler engine, 420 used Onan. 400's were "attachment specific", meaning most attachments do not interchange. Don't think (not sure) the 400 had a two-speed trans-axle or differential lock. ~~ grnspot110
   / Is a JD 400 a good parts machine for a JD 420??? #5
Correct on the Kohler to Onan engine difference. The 400 did have a two speed axle but did not have diff lock.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Ryobi Compound Miter Saw (A48837)
Ryobi Compound...
2022 Toro TX 1000 Wide Track Mini Skid Steer Loader (A50490)
2022 Toro TX 1000...
Kobelco SK200SR LC Excavator (A50860)
Kobelco SK200SR LC...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50505)
2018 FREIGHTLINER...
Nortrac Three Point Hitch Cement Mixer (A48837)
Nortrac Three...
