is a chain harrow the right tool
   / is a chain harrow the right tool #1
04Fatboy
Or
Kubota B6200
i have about 1.5 acres i am trying to get some grass planted. it was bare land that we clearer underbrush and blackberries to get our house in. we still hace alot of fir trees. i have spent some time with my box blade getting the roots and clumps out. i do not want to tell the whole place so i was looking at a chain harrow to drag around. and get the dirt to look a bit better. i am not looking for perfect lawn just grass. also what is a good all around type of grass. it is a shady area with the fir trees and I am in the pacific northwest (near Portland Oregon)
thank you alll!!!!!!
BOB
   / is a chain harrow the right tool #2
If you are trying to get seams in the ground for the grass seed to get in, dragging several times with a blanket harrow (they look like a very heavy chain link fence with prongs which penetrate the ground) can work. You should also follow seeding with a roller, or turn the blanket harrow upside down to smooth.
If the ground is still a little rough, though, I think discing would give you better resulsts in the long run.
   / is a chain harrow the right tool #3
Discing is probably the better option to break up the soil, then drag it with a harrow to smooth it out. Once the seed is down drag it again or roll it. Then water forever...
For the seed, checkout outsidepride.com and research what you need for your soil and growing needs. There are also plenty of other sites that will help you determine the seed you want, just google away and research 'till you're sick of it!
   / is a chain harrow the right tool #4
If you don't have big clods.. then yeah.. a chain harrow will work. if ya got big clods and big windrows/gouged.. maw want to disc it .. then drag it.. etc..
Soundguy
BOB
   / is a chain harrow the right tool #5
All depends how rough the ground is now. After box-blading I would think it would be fairly smooth. In that case a chain harrow may work very well. However, if it's seriously rutted and clodded, the chain harrow won't do a lot and the disc might be needed. What do you already own besides the box blade?
This past spring I turned 5 acres of weeds into hopefully a new hayfield. I did 1.5 acres with only scarifier teeth and a chain harrow. The other 3.5 I used a disc between those steps. The area that got disked is much smoother, but only because all of it had been scarified first. I don't own a box blade and didn't try using my grader blade. I wouldn't buy a disc for only this purpose because they are quite pricey and may bring up enough weed seeds to offset the smoothing benefit.
As for grass choices - well, Oregon is where most of the US's grass seed is grown. There should be lots of choices. Decide if you want mere groundcover or something to feed wildlife or livestock first, because it will be different seed choices. Then go discuss with your local seed supplier, farmer's co-op, etc. They may have a seed catalog that you can browse and try to guess what will work best. Look up the website for a supplier called "Forage First". I'm guessing a mix of perennial ryegrass and fescue will be a good bet, but it's only a guess. Kentucky Bluegrass may also be good if you basically want a lawn. These three grasses are the most common lawn grasses in areas that don't get super hot or dry. If you want to attract wildlife, you'll want more than just grasses. If you want to pasture horses or cattle, you'll want high yielding grasses, may need high traffic tolerance, and you won't want turf type fescues because of a fungus that grows in them that's bad for most grazing animals.
Thank you for the info
I only have a box blade and brush cutter right now. On a tight budget due to the new house and land. I am not looking at farming at all. and will have small areas of "Lawn" near the house. This is basic ground cover that will be cut once a month at the most. My lawn will be my nice area.
So far the box blade has done a gteat job. I just do not want to be using a rake in my hand for 2 acres!!! With the chain / Blanket harrow it looks like I should get a boom pole also to pick it up? The one with a full fram is over my budget.
BOB
   / is a chain harrow the right tool #7
I have the same two implements as you, BB and RC. Use the BB to do it. After rooting and grubbing lower your scarifiers all the way and roll the box forward by shorteneing the top link all the way. Now go round and round. This is a chisel plow and is tilling the soil. The tilled soil will be smoothed and now is the time to knock down big high spots and fill big low spots if desired. Then raise the scarifiers all the way and roll the box the other way by lengthening the top link which will set the rear blade of the box to "smear". Lower the box all the way and go round and round. This process is free of cost.
Now see if you are happy. If you want a smoother appearance for your pasture then you can look for something flexible to drag like a chain harrow or some chain link fence etc.
Being pasture though the box scraper can get fine results.
   / is a chain harrow the right tool #8
I also think this would be the best way and what I would do on a small (ish) area. Roll the BB right forward and tines right down. Drive round and round and round untill it all gets broken up well. Then, get either a new chain harrow or get a bed spring or chain link fence and drag that around lots. This will give you a nice seedbed. Then, throw down the seed and preferably roll the seed in, it likes to be in firm contact with the soil and moisture, but not buried, or lightly drag the harrow or chain link over it once.
GREAT
I never thought of rolling the box forward to get the scarfers down further and not drag so much dirt around. TBN rules to help us rookies!!!!
thank you for the advice and I hope more keeps coming
   / is a chain harrow the right tool #10
04Fatboy said:
GREAT
Yes, you can really scratch pretty deeply this way and all of those scarifiers will really put a load on the machine. Go ahead and let the box set down as far as it will go without the blade touching in the rear for maximum tilling effect. My backyard is setting now in the tilled stage awaiting some cooler weather to smooth and seed.
2009 Yamaha Golf Cart (A52377)
2009 Yamaha Golf...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2023 ALLMAND MAXI-POWER 15XR GENERATOR (A53843)
2023 ALLMAND...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
