Irrigation
   / Irrigation #1
Jonnyzebra
1948 8n 1979 140 HiClear
Looking for suggestions on how to build a clean source of water for vegetable irrigation from a low area. 50 years ago it fed a house. Looks like it was a springhouse sort of arrangement. There is plenty of water I just need to collect it cleanly so I can pump it. ThanKs for any suggestions
   / Irrigation #3
You can use rain water too, if you have plenty.
   / Irrigation
What I'm looking for are suggestions on how to construct a source for water from a swampy area. I will be feeding 2 acres of veggies. I was thinking maybe 55 gallon drums connected and surrounded by gravel? any thoughts
   / Irrigation #7
Might consider a swimming pool sand filter with a backwash valve that allows you to flush it clean as needed. For the pickup I would want a large screened (use shaker screen) box with plenty of surface area to block the larger trash. You can use a push broom to clean of trash from the screen.
   / Irrigation #8
Welcome to TBN
I water less area but basically I just dug a hole in a swampy area and made sure the pump inlet hose was suspended between the bottom and surface. The little "pond" acted as a settling basin. Eventually we dug out the swampy area completely and now have a big pond. Your idea of barrels and gravel should work fine but if the hole is big enough you won't need the barrels :thumbsup:
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
TMA (A49461)
TMA (A49461)
