Irrigation System
/ Irrigation System #1
ChrisJ
New Hampshire
MF 1428v, gear
I'm another newbie in the tractor biz. I want to install a lawn irrigation system on 2+ acres of lawn. I was browsing the northern tool site and saw a middle buster, I was curious if this tool would do the trick digging the 6"-8" trench I want to dig. I'll be pulling it behind 28horse mf. The implement is cheap enough I might just buy it and try it, it will at least work for my dogs underground fence.
CJ
/ Irrigation System #2
My father in law used one to install his sprinkler system. He told me that it worked very good for digging the trenches for the pipe.
/ Irrigation System #3
See also some threads on these boards concerning using a modified middle-buster to either lay flexible pipe or pull flexible pipe into the ground like a poor-man's vibratory plow without worrying about clearing the trench.
- Rick
/ Irrigation System #4
Ditto what Keeney said. There is GREAT post with photos of a modified mid-buster used for your exact application. Basically, the guy attached a smooth bend 90 degree pipe to the back of the mid-buster and fed his irrigation pipe through it. He clamped a guide on his rops and guided the pipe over his tractor into the pipe and therefore the ditch made by the mid-buster....a real slick one man operation. If i find the post i will add it here.
Peter
/ Irrigation System #5
Hope this is the reight one and helps you...not my idea at all but I thought it was very well done.
Peter
Laying pipe the easy way
/ Irrigation System
Thanks for the help. I'll give it a whirl.
/ Irrigation System #7
Certainly worth a try, do check into what it takes to do a irrigation system correctly. If you check the Hunter or RainBird catalogs, they give you PSI loss per 100' of pipe based on the pipe (class 200, SCH 40, copper, etc.), based on the gpm flowing through the pipe. Better yet, go to the following link and armed with each heads gpm, pipe length, you can figure out quite a bit of what you need.
RainBird irrigation calculator. Rat...
/ Irrigation System #8
Yes.. I trenched a small water line to my chicken pen using only 1 tooth in my box blade...
Soundguy
/ Irrigation System #9
Unless you live in a very sandy soil area that tends to be dry and hot, why do you need a sprinkler system to water grass?
Kentucky Blue is probably the best grass for there. It just goes dormant if it doesn't get enough water. It doesn't die unless it's abused a lot.
Ralph
/ Irrigation System
My land was just reclaimed from an old gravel pit, the grael is perfect for highways. It's definitely not good for moisture retention and there are no trees to shade anything. I've basically got 8" of loam on top of super draining gravel, my septic system will never fail, but my lawn has been struggling. To top it all off, the area is treed predominantly with white pine and all the soil is extremely acidic. I've put a ton of lime and fertilizer to it, but the sun dries up whatever starts to grow. My well gets 35+ gallons a minute, I figure I can irrigate a good portion of the 3+ acres of lawn area. Also hoping the few hundred christmas trees planted about will get growing and create some shade.
/ Irrigation System #11
Of course Ralph you must be speaking for folks back East. Here in California we won't see much if any rain now until November. Irrigation is what everyone one out here does from about April on. It's probably what helped RainBird, Hunter etc., so successful. Rat.
/ Irrigation System #12
Chris, mind my asking what size pump you have on your well to get that many GPM?
/ Irrigation System
My well produces 35 gpm, my pump won't do that much, but I'm safe from it running dry when I'm irrigating the lawn.
/ Irrigation System #14
I have a well that recovers an estimated 35 GPM. I have a 1.5 HP submersible pump that pushes 15 GPM at the head. I run 10 zones with 5 Toro High Volume heads on each at the maximum needle and I maintain 55 PSI. I put 1350 gallons of water on my lawn a day. Takes 1.5 hours to water and acre and a quarter. I use the Scots 4 step program and my lawn looks like a carpet. I usually don’t start watering here until mid June. /forums/images/graemlins/cool.gif
FIXED FIFTH WHEEL ATTACHMENT (A65643)
FIXED FIFTH WHEEL...
Case IH 800 (A64127)
24in excavator tooth bucket (A61307)
24in excavator...
Rut MFG Mini Excavator Brush Cutter (A64126)
Rut MFG Mini...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
Jack Daniels Sign (A64127)
Jack Daniels Sign...
