I have a lot of thoughts here. Feel free to comment on any of them as I am new to farming, etc, but am enjoying learning about it.
I wish to develop an water source for irrigation of about half an acre of gardens consisting of everything from above ground sprinklers to extensive drip irrigation to taps and hoses for manual watering. I have about a 2 acre pond that I can draw water from. It stays usually full from runoff but can get low in drought.
I wanted to drill a water well, but that is another story. Seems my area is just outside the known aquafers in the area and 2 drilling companies recommended against trying. In addition, I have heard that there will come a time soon when we will be taxed for the water metered from our private wells (Texas) (but that's another thread, I guess.)
I have a creek that is 1250 ft away and 40 vertical feet below on my property which flows about 150 gal/min all year. I am constantly hunting for a 'deal' on pvc pipe and wire to set up a pump / pipeline system to get the water to the gardening area and / or to the pond to keep it full.
But I am mainly inquiring about how to process water from the pond for irrigation including drip, which is sensitive to dirty water. I have found some good designs for intake screens from the pond.
Next, I need a pump. Does it need to be a 'trash' pump incase I get crud into the system? Is a 'clear water' pump too sensitive for occasional bits of debris that may enter the system.
Then I want some sort of 'low maintanence' filter. Either something that is large enough that it doesn't need to be cleaned more than once a week or a system that can be either manually or automatically backwashed less than once a week. I am thinking that maybe a used pool 'sand filter' from craigslist might work. I am also familiar with 'cartidge filters' for pool use although cleaning them is a pain and the replacement cartridges are expensive.
I have searched this forum for this topic and have seen mesh filters mentioned as well, lthough mesh filters don't seem to handle algae well.
Any ideas here?
DJ
Any ideas here?
DJ
