IR 60 gal Air Compressor oiled
   / IR 60 gal Air Compressor oiled #11
Will parts be available for that brand or another brand when it breaks, and it will break.
I have an old Sanborn compressor that the relief valve failed on. That part not available according to a phone call to Sanborn so it was basically junk because of a 10 dollar not available part.
I had a Sanborn for over 20 years. Bought it from Northern Tool years ago. The safety relief valve went on mine and I replaced it with another from a local store. You should be able to get it most anywhere. It has standard threads and I think it was rated at 125 lb. but other ratings are available. The bottom of my tank finally gave way to rust (mainly from sitting year round in an damp unheated pole barn). Gave the whole thing to a friend of mine who swapped the compressor onto another tank he had and its still running. I replaced mine with an 175 lb max, 80 gallon 2 stage compressor bought from Home Depot. Its the Husky brand made by Campbell Hausfeld and distributed by HD.
   / IR 60 gal Air Compressor oiled #12
I have a 60 Gal CH brand as well...5HP, 60gal 135psi...7 years and not one issue yet. I use it quite a bit for painting, ait tools etc...have to let it catch up on high volume tools like line sanders, but a minor inconvenience.
If you shop the compressors, you'll probably notice that all of the non-commercial brands look nearly identical...One company with multiple badging is my guess.
   / IR 60 gal Air Compressor oiled #13
Yep, I didn't know Campbell-Hausfeld made the Husky, but I'm not surprised. All the Craftsman compressors I've seen were made by DeVilbiss and I'm currently using a 30 gallon Industrial Air by Coleman Powermate that I bought from Northern Tool. I turned the pressure down to 40 psi this morning and used my little one quart Campbell-Hausfeld paint gun to spray Sherwin-Williams Deckscape on my wooden fence. Then I turned it back full 125-150 psi to use a blow gun to clean the Stihl string trimmer and then the Toro ZTR after I finished mowing, edging, and trimming the yard and a neighbor's yard. I don't know now anyone can get along without a decent air-compressor.
   / IR 60 gal Air Compressor oiled #14
Perhaps I should have mentioned that the Pumas are made in Taiwan. I'm sure that might matter to some. I don't know where the Ingersoll-Rand compressors are made. I didn't ask to see a manual for it, but did look at an Ingersoll-Rand compressor at Northern Tool this morning to see if any of the stickers on it told where it was made, but didn't find that information. And the Lewisville Northern Tool store only had the little Puma compressors in stock (or at least out on display). Of course most air tools, including Ingersoll-Rand, Snap-On, Chicago Pneumatic, etc. are made in Japan with a few made in Taiwan.
I would think Taiwan would be better than mainland China.
   / IR 60 gal Air Compressor oiled #16
Not to jack the thread (well, maybe a little), but I'm a little hazy on two-stage compressors. Does a two-stage compressor use a second cylinder to get the extra pressure, or is there such thing as a single-cylinder, two-stage compressor?
This one looks like a single-cylinder, but says it's two-stage.
80 Gallon 2-Stage Air Compressor, 5 HP - 3496129 | Tractor Supply Company
   / IR 60 gal Air Compressor oiled #17
Runner, it'll be a 2 cylinder. Maybe this website explains it about as well as any. And it's not unusual for vertical compressors (as opposed to V-twins) to look like one piece. In fact, my current little single stage 30 gallon upright has 2 cylinders, so just a look at the exterior doesn't fully explain. And the V-twin Puma I mentioned is also 2 cylinders but a single stage. In other words, both cylinders pump air into the tank instead of one cylinder pumping air to a second cylinder which in turn pumps air into the tank.
   / IR 60 gal Air Compressor oiled #18
i used to have a Ingersoll rand compressor ...had it for 15 years. was a fine piece of machinery.
I currently have a Kobalt (Lowes) 60 gallon vertical unit ...its a single stage but has more than enuf output to keep up with my CNC Plasma bench.
If it ever dies (5 years going strong) I'm planning on either getting a nice 2 stage unit from napa ($2,400.00) or a screw compressor from the local compressor store (its an ingersoll rand unit)...but that costs closer to $4,000. The screw compressors are far superior units, but not sure if i can justify the cost difference though. Some of the screw units ive been near are fairly quiet, some are noisier then He**...SO I WOULD DEFINITELY NEED TO HEAR THE UNITS RUN.. Some day ill build that outdoor air compressor shed that i keep talking about......someday.
ALSO: not to hijack the thread...but if you have an extra $400 lying around. think about adding a dryer unit to your system. I added the one from Harbor freight about 3 years ago
http://www.harborfreight.com/compressed-air-dryer-40211.html
has worked flawlessly and takes nearly 100% of the water out of the system. I used to have to remove and dry my filters daily. One set of filters had replaceable elements that cost about $15.00 each time i replaced them (havnt needed to replace for 3 years...was replacing every month) now everytime i check them...there always completely dry. the unit is amazing. especially usefull if you plan on painting.
   / IR 60 gal Air Compressor oiled #19
I am generally an Ingersoll-Rand fan when it comes to air tools, but have no experience with their compressors. I only recently learned that Northern Tool was selling the Puma compressors. I did not buy my Puma compressor from Northern Tool. At one time, I'd had a brief repair experience with Industrial Air of Texas and liked them. In December, 1998, they were located on South Cooper Street in Arlington. On 12/9/98, I noticed the Puma showed "6 hp". The salesman said, "We call it an imitation 6 hp." He then showed me one of their own real 5 hp electric motors on an 80 gallon 2 stage compressor and of course it was twice as big as the Puma compressor motor. But he said they had some of the Pumas in shops running all day 5 or 6 days a week and never had a complaint. I'm not sure exactly what the price of the compressor was, but I find in my records that I paid them $617.61 that day, including some fittings, pressure regulator/filter, sales tax, etc. It was a fine compressor and never gave me any trouble at all, but of course, I only had it nearly 4 years. When I had to move back to town, the realtor who sold our place out in the country, bought that compressor from me (he had a ranch in the same county himself).
Now I see, assuming it's the same company, now in Grand Prairie, that they don't list the Puma as one of their brands so perhaps the Ingersoll-Rand is the better choice if you're concerned with parts in the future. Personally, I'd go with the Puma because I like that V-twin design and had such good luck with mine, but I can certainly understand reasons others may make a different choice.
Just a quick question Bird...are those air lines plastic??
if so please beware. a friend of mine had run plastic lines......they exploded. Luckly no one was in the shop at the time. it shattered a window and had embedded shards in the insulation.
i ran mine in copper pipe after i saw the results of his mess.
Well the sale expired and I have not bought a compressor yet. One question - seems in some reviews people are saying the compressors they purchase are not ready to use. Seems they have to add a regulator? I assume this determines what the air pressure is coming out of the hose. Every compressor I have seen (smaller ones) have that already included.
Also, on the 230 volt models it appears there is no power cable, it has to wired in. I figured on fixing a plug to plug into the same outlet in my shop as my welder, but some reviews indicate you have to hardwire it direct to the circuit breaker?
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2019 International HX620 T/A Wet Kit Day Cab Truck Tractor (A55973)
2019 International...
Zero Turn Mower (A55853)
Zero Turn Mower...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
