Inverter
   / Inverter #1
daedong
Veteran Member
South Australia
Can someone tell me what i can run with a moderfied sine wave inverter. Can i run a TV, CD player, or fluro lights?
   / Inverter #2
You should be able to run all of those. My home is "off the grid" and I used a modified sine wave inverter for many years to power everything except washer, dryer and well (ran a generator for them).
Sometimes (depending on inverter model) you can get buzzing or lines on a tv. I also had a "situation" with a compact fluorescent light and a cheap surround sound amplifier: they were only a few feet apart and when the light was turned on, it would make the amp do weird things. Finally got a better amp and the problem went away.
Currently I use that old inverter to power a jet pump for our water pressure, and two sine-wave inverters (one for lights and entertainment, the other for everything else including washer and dryer).
Oh (on edit) VIN: NICE HOUSEBOAT!!!
   / Inverter #3
I run a trace 2500 watt inverter conected to 8 trojan T105 batteries in my garage for those lights out moments.
If it lasts a long time I have a diesel 12 kw. gen set that runs the place & charges the batteries at the same time. /forums/images/graemlins/smirk.gif
Ern.
   / Inverter #4
I agree with the others.. a m/s/w inverter should be fine.
Soundguy
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
