Inverter arc welder
   / Inverter arc welder #11
i have an everlast 140 .i use it on a 5500 watt generator.it runs it full power but i can not see a 5500 watt generator running anything any bigger.i have a 220 plug on mine.so far i like the welder.i think i have had it at least 6 months.1/8 6011 will weld 1 inch steel with multipasses.if you get the everlast 140 plan on getting some longer cables.good luck
Thanks cowski!
I would be planning on installing 220 with a 50 amp breaker in the garage to run a bigger machine. But I could always use the generator when using the equipment at lower power.
   / Inverter arc welder #13
After completing all the welding courses at the local college I find myself a diehard Miller fan--I fell in love with the Dynasty 200 SMAW/GTAW, yet I sadly still have to make due with a pitiful income due to the lack of welding jobs locally and cannot afford 4k for the stick welder of my dreams. Like you mentioned, the Maxstar and Thunderbolt series welders are still far beyond my current reach and I have resigned myself to living with a Lincoln AC buzzbox which I managed to pick up for $60. AC welding leaves much to be desired when it comes to stick; you don't end up creating welds you'd want to take pictures of and post here..
Having owned a harbor freight 110 mig box.. I can now say I've tried some of the best and worst welders out there, yet HF left me with the idea that one has to buy the best to get a product that is worth anything more than a paperweight. Yet after the comments here, and looking over both everlast and longevity websites I have high hopes.
I would agree with previous comments that 140 amps is more than sufficient for most at home in the stick process. If you aren't currently competent in welding (and it's always best to be honest with ones self in this regard, our lives are on the line at times with the things we build) An introductory welding class at a local college should make you confident in laying multi pass welds and give you an eye for creating equal legs, welding thinner material to thicker, etc.
The only downside for me is the duty cycle; (3.5 minutes in 10 of weld time gives you a lot of cigarette breaks) yet unless you're running a business from your garage it's best not to be in a hurry anyway--gives the metal time to cool, and your chances for heat related defects become less.
And last but not least, if TBN promotes everlast and longevity then I'd imagine they are pretty decent tools indeed. Just the fact that one could buy the 140 smaw welder and a 40 amp plasma cutter for much less than the 150 maxstar alone.. well.. I'm sold! 'nuff said.
Thanks for your additions Dan. While I'm not an experienced welder yet, I do my homework, and luckily there is lots of available resources here on the net. I probably have some insight on endothermic bonds that many welders might not. But either way I learn fast and have some pretty good intuition. Being a tool junky doesn't hurt either. I have already done a few welding projects and am ready to graduate from my 110 flux core mig to something that is going to last me the rest of my life. I am not up for buying a small unit that I'll have to replace in a year with a bigger more capable unit. Besides, I've got some steel and plans for a tractor implement already lined up waiting for the equipment to work it.
I already bought a PowerArc 300 and am waiting on it to arrive. I liked the features of the Stickweld with the adjustable arc force and hot start but have decided on an Everlast and the 300 has the features I want. I have a few things to do before it gets here and probably won't really be ready by the time it arrives. Anyway, I'll be sure to post some pics when I unbox it and then after I get some welds in.
   / Inverter arc welder #15
I have an Everlast PA200 and like it a lot. I've gotten the hankering to add mig to the stable, so after a bit of looking around, have decided on the MTS 200 when money allows. Can't argue with 200A of synergic mig, 200A lift start tig, and 160A stick in one unit for $800 (20% TBN discount figured into that number) I haven't used the PA200 over about 135A for welding, so losing 40A from the PA200 won't affect me much, except duty cycle and even that reduced number will be over 50% in the range I generally weld in.
Ian
New/Unused 72inch Quick Attach Rock Grapple Bucket (A54865)
New/Unused 72inch...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
Scissor Lift (A55973)
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
