INTERNATIONAL UTILITY 350 Hydraulics not connected "need expert help"
   / INTERNATIONAL UTILITY 350 Hydraulics not connected "need expert help" #1
bigrigford
OxfordMills Ontario
Looking
INTERNATIONAL UTILITY 350 Hydraulics not connected "need help"
I looked at the above last night and the seller showed me a hydraulic pump and a long double tube that he said mounted between the distributor and motor, and the tube connected to the pump and ran up to connect to the tank under the seat.
Does any one know if this is correct and does any one have drawings of how the pump mounts?
thanks
Dave
   / INTERNATIONAL UTILITY 350 Hydraulics not connected "need expert help" #2
Re: INTERNATIONAL UTILITY 350 Hydraulics not connected "need help"
The pump mounts between the motor and distributor. The lines should go from the bottom of the pump to the tank under the seat. There are some parts diagrams that might help at caseih dot com. The front of the pump should have a gear that meshes with the timing gear train . The rear of the pump should have a hub that mates to a drive tang on the distributor housing. These pumps cost about $700 if it is bad.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
71063 (A49346)
71063 (A49346)
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
