International TD6
/ International TD6 #1
TWD
Sierra Nevada Mountains - CA
Kubota M59
What's a running international TD6 worth? and how hard are parts? cost of parts?
-No restoration.
-Looks like home made dozer blade with hydro (works).
-Running condition, possible clutch slipping.
Also, what is their gross weight?
/ International TD6 #2
Don't have a clue about the worth or parts, but here are some specs. .
International Harvester TD-6
Production years: 1940 - 1956
Next model: International Harvester TD-6 Series 61
Tractor type: Farm/Agricultural tractor
Overview
Engine
Transmission
Dimensions
Tests
Photos
Production:
Manufacturer: International Harvester
Factory: Melrose Park, Illinois, USA
Total built: 38,450
Original price (USD): -unknown-
Variants:
T-6: gasoline engine
International Harvester TD-6 Engine:
International Harvester 4-cyl diesel
full engine details ...
Capacity:
Fuel: 20 gal [75.7 L]
Aux. fuel: 0.66 gal [2.5 L]
Dimensions & Tires:
Wheelbase: -unknown-
Weight: 7280 to 7800 pounds
Front tire: tracks
Rear tire: tracks
full dimensions and tires ...
TD-6 Serial Numbers:
1940: 501
1941: 4435
1942: 8191
1943: 9297
1944: 9581
1945: 10828
1946: 12056
1947: 14516
1948: 17349
1949: 21146
1950: 24862
1951: 27536
1952: 31056
1953: 33157
1954: 35746
1955: 37470
1956: 38706
how to read serial numbers...
International Harvester TD-6 Power:
Drawbar (claimed): 22- hp [16.4 kW]
Belt (claimed): 31 hp [23.1 kW]
Plows: 4
Drawbar (tested): 31.75 hp [23.7 kW]
Belt (tested): 38.20 hp [28.5 kW]
power test details ...
Mechanical:
Chassis: crawler
Steering: -unknown-
Brakes: -unknown-
Electrical:
Ground: -unknown-
Battery:
Number: 2
Volts: 6
Page information:
Last update: August 11, 2010
Copyright: Copyright 2010 TractorData LLC
Contact: Peter@TractorData.com
Copyright 2005-2010 - TractorData LLC. Notice: Every attempt is made to ensure the data listed is accurate. However, differences between sources, incomplete listings, errors, and data entry mistakes do occur. Consult official literature from the manufacturer before attempting any service or repair.
/ International TD6 #4
here is a link to machinery trader. There is only two on there but it can give you an estimate of value INTERNATIONAL TD6, Used INTERNATIONAL TD6, INTERNATIONAL TD6 For Sale At MachineryTrader.com - Page 1
As far as parts, try some websites like ytmag.com to see what is avaliable for that machine Discount Tractor Parts and Manuals for Older and Antique Tractors
I am not certain but I am sure that IH used that same motor in other tractors/equipment as well. They dont make a totally different engine for everything. So you may want to do some more searching and digging to see if that motor was used in some more popular tractors as well.
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2008 Ford Expedition SUV (A61574)
2008 Ford...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
