Rotary Cutter International rotary cutter
   / International rotary cutter #1
Anonymous Poster
Epic Contributor
Has anyone heard of a International rotary cutter or another term(bush hog)? There is a local dealer that sells them ,a five footer for $675.00 with shear pin and $875.00 with slip clutch. I' ve never heard mention of one here. It looks to be of high quality. I am cutting about 10 acres mostly grass but I want to get medium duty in case I do some heavier stuff. Any thoughts?
   / International rotary cutter #2
<font color=blue>… Has anyone heard of a International rotary cutter…</font color=blue>
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-229651-InternationalRotaryCutters-800.jpg>They appear to be similar to KingKutter style</A>, but what I like better is the thick stump jumpers they use… ½” – ¾” pan cut steel versus 3/16” on most standard pans… This mass will allow a smaller PTO hp tractor to sustain cutting in tougher woody material or higher grass… in turn helping to get the max torque out of your tractor… /w3tcompact/icons/smile.gif
One of the weak areas as with all the cheaper rotary cutters is the A-frame assembly… not solid enough for everyday rough cutting duties… tends to twist and bend as time goes on… /w3tcompact/icons/frown.gif
   / International rotary cutter #3
John..........I'm looking to purchase a 6' light/ medium duty cutter.........A local dealer has both Howse and King cutter available both with a 40 HP gearbox....The KK is $100 more.........Is it worth the difference??.........I've had KK products before with decent results.......Tom
   / International rotary cutter #4
<font color=blue>… I'm looking to purchase a 6' light/ medium duty cutter…</font color=blue>
Hi Tom…
First… big price difference between “light/standard” duty and “medium” duty… as well as construction differences… /w3tcompact/icons/blush.gif
I have owned both… and I really bad-mouthed Howse for a time… maybe they had a bad batch/run when they made mine and some friends a few years back… With that said, I’ve seen some older Howse units, I’ve had to look at twice to make sure it was the same company… when I saw the massive steel deck and skids and A-frames used (MD units)… and I’ve seen some newer units that looked much better than my purchase… all-in-all though, I found KingKutter to have better overall manufacturing consistency…
Let your eyes and gut be the judge by looking at both of them side by side, especially on a standard duty unit… basically both should have 40 hp rated gearboxes (I know for a fact the Omni 40 hp box on KK will do 60hp on an “severe” intermittent basis /w3tcompact/icons/eyes.gif) Also, Howse may be trying to get more market share, as I’ve seen 5’ Howse units at auctions brand New for as low as $400…
My personal opinion, KK makes a great entry level, most bang for the buck standard rotary cutter… but if you are considering medium duty or higher… then for only a few dollars more… I’d consider other mfrs..
   / International rotary cutter #5
Was it built by Int. or just red paint with their sticker?
As far as implements go, I tend to go with the heavier guage metal on the deck, sides, and hp rating of the gear box. Guess a fellow has to satisfy himself as to how much he wants to spend as to how heavy a tool he can find.
clutch
We sell that brand and stock all parts for them. That pricing you got, may be a tad high--We sell the IM 500 (International, Made in Bethel, Ohio) 5 ft with shearpin for $599 and $699 with clutch. I have sold most brands of Brush Hogs in the 26 years in the retail business and the International will give you more bang for the buck than Howse or KK.--Ken Sweet
Sweet Farm Equipment Co
<A target="_blank" HREF=http://www.sweettractors.com>http://www.sweettractors.com</A>
   / International rotary cutter #7
Hey Sweet: I tried you're link it was dead...
Where are you located. Ive looked at the International units they are pretty nice I have a local supplier which is higher by a lot. I'm in norhtern ohio.
Mark
   / International rotary cutter #8
where would you find the specs on these cutters?i,m in the market.bws
Hello Mark--Our Website host is doing a major upgrade this weekend--be back up
Sunday or Monday AM at the latest--we are about 2 hours southwest of Cincy in
central Ky--thanks-Ken Sweet
   / International rotary cutter #10
We sell the International Rotary Cutters. For the money I don't think you can beat them. We have sold them for a couple of years and haven't had a single one come back yet. They are tough and ugly. Paint could be better but who cares if a rotary is pretty?
KO
(4) Radial ST 225/75 R15 Tires (A50121)
(4) Radial ST...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
1997 Semi Dump Trailer (A50514)
1997 Semi Dump...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
